New front brakes
New front brakes
Post by pinzinator »
My 1974 710M was beginning to stop erratically, pulling to the left. So I got the floor jack and jack stands out to do some investigation.
IMG_0881 - Copy.JPG (351.56 KiB) Viewed 5286 times
No surprise here, the right side had a wheel cylinder that leaked and soaked the brake shoes. What an easy diagnosis!
IMG_0886 - Copy.JPG (371.82 KiB) Viewed 5286 times
I removed all the parts and cleaned the backing plate as best I could, then ordered cylinder rebuild kits and new brake hoses.
IMG_0884 - Copy.JPG (336.43 KiB) Viewed 5286 times
The brake drum was fairly new and just needed a good cleaning and the braking surface scuffed up.
IMG_0894 - Copy.JPG (301.76 KiB) Viewed 5286 times
My good buddy Mike Nims had once suggested replacing the power booster, so I set about removing the old one. I already had a new booster on the shelf.
IMG_0897 - Copy.JPG (362.28 KiB) Viewed 5286 times
Removing the booster wasn't difficult, except for the upper rear mounting nut. The clutch slave cylinder had to be removed to gain access. The easiest way to loosen the nut was with an offset wrench, and even more difficult to reinstall.
