Brake wizard needed in Costa Rica. Maybe I'll pay your way
Someone please help with this brake dilemma. My Pinz is located in Costa Rica and every year I need to pass a safety inspection the likes of nothing I have ever had to deal with anywhere else...( Russia, Africa, USA).. None of them come close.. Anyway. I just failed another 6 times in three days trying to get the brakes to pass. Its all computer analyzed up on rollers and the fronts will grab like no bodies business but I cannot get anything to the rears. Always happens that way. I made some metal hoops of 1 inch wide steel to wrap around rear shoes to keep wheel cyliders from blowing the seals out while I had someone working the brake pedal just so I could see what was going on. Rears do not even think of moving with a slow steady push off the pedal like they demand at the inspection. If my helper stabs the pedal hard and fast there is some movement the rears but not impressive by any means. Won't even come close to the specs needed to pass. I have tried everything over the years. All new wheel cylinders, new lines and hoses, new master, new shoes.. machined drums incase they were warped, bled the system so many times I cant count. Tried backing way off on adjustments of fronts to allow more pedal travel hoping it will help the rears (Nope!)....Even adjusted rears so tight they would have been smoking if I drove more then the 200 meters to get it back to the inspection place.. I am at a loss and ready to treat someone to a full on Costa Rica adventure holiday if you have some ideas that might work. I am dead serious. This inspection nightmare costs me loads of dough every year, undue stress etc....and once you fail, you are a marked man. The cops nab you driving after the fail and there goes your Pinz off to the impound and sell your soul to get it back. It's a three hour drive just to get to the damned place so I am sticking my red neck out there......I am open to any and all suggestions. Is there a proportioning valve I am unaware of?
Re: Brake wizard needed in Costa Rica. Maybe I'll pay your way
On one of the 710M's I bought years back, I had a similar problem with lack of braking in one circuit. It turned out that one of the Static Pressure Valves, part # 7103366220, had been installed backwards preventing the flow of brake fluid.
The attached photo has the 2 valves marked with arrows. Worth a look anyway.
Thanks a lot for the tip. I am hitting the trail to hike out of the jungle now to get a look and see what is up in there on that master. Man that would be so great if that is the issue. I do get some action to the rears if the pedal is pumped up so maybe that valve is an issue.. Or non existent. Thanks for the tip..
- Hotzenplotz
Just out of curiosity: did you
You could also have an issue with the master cylinder leaking between front and rear. The left (outside) pipe supplies the front axle and the one closer to the servo the rear axle. There is a floating piston between these spaces in the master cylinder. If that piston leaks you have the symptoms you describe.
- adjust the rear brakes ?
- bleed the rear brakes ?
- if you bled them, was the fluid trickling or spraying ?
Albert
Albert
[quote=Hotzenplotz
I assume your Pinz is of Swiss Origin; they have one circuit for the front and one for the rear.
[/quote]
Out of curiosity, is the Austrian brake circuit different?
[/quote]
- Hotzenplotz
yep, it is ...
There are two single brake cylinders on each front wheel and a single tandem cylinder on a rear wheel, in both versions
the Swiss setup has both single cylinders of both front wheels on a connection of the master cylinder, and both tandem cylinders of the rear axle on the other one.
the Austrian setup requires more piping, but creates logical triangles,
there the cylinders of each front wheel are allocated to different circuits, and a rear wheel tandem cylinder is added to the group.
As a result the Swiss model fails either front or rear axle with a failed circuit. the Austrian setup fails half of the braking power at the front axle and one rear wheel
Albert
Albert
Hi...Thanks folksnfor taking the time to help out...The schematic you show of the brakes is not my rig. I have one steel tube that feeds one of the front wheel cylinders and then a short steel tube that leaves that cylinder and goes to the second wheel cylinder of the same wheel. Brakes have been adjusted and bled many times. Master has been replaced in hopes of solving this issue, but it did not... so not likely the master.. Though I guess it could be bad off the shelf. But a real long shot that it would present with the same symptoms. Tempted to see how easy it would be to swap the lines at the master just to see if the problem shifts from back to front.
- Hotzenplotz
so your layout is this
you mentioned at the begin that you had the drums machined. New drums have a diameter of 285 mm. they nay be machined to 287, but the shoes have to be machined, too.
try swapping shoes and drums from front to rear ....
when bleeding did you see the brake fluid coming with the same pressure at both axles ?junglefever wrote: ↑Tue Mar 30, 2021 6:26 pm ..... Brakes have been adjusted and bled many times. ...
Albert
Albert
Yes, this is my system. I had the same issues before the drums were machined (but that seemed to squeak me past the inspection last year) so I guess it added just enough friction to make the computer happy. I knew it would change the geometry when machining, but decided to take a chance as a last ditch effort in a place where I have limited tools. I would kill to have my whole shop airlifted to Costa Rica.
As for your questions. Well, I never get a real nice strong stream when bleeding the backs.. Nothing like the fronts anyway. That always led me to think the master was weak or the fronts were so close that the pedal stalled out too fast not allowing for rears to get full pressure. But after changing out the master and then backing way off on the front shoes and still having less than ideal pressure when bleeding the rears it kind of stumped me. That is when I decided to change all the rubber lines just incase one had internal collapsing issues going on. I begged the guy machine the drums to just skim them to get rid of any runout and he did just that. I did not have a mic to check the dia real accurately but now that I have those specs (thanks for that) I will sort out a way to check them for dia now. Do you know what the specs should be on the thickness of the lining when new? I have a full set of old shoes down here and was considering getting them relined. That I know I can have done here. Would save me hauling all new sets down on a plane. I cringe at the thought of hauling down 4 new drums. Yikes! Is there any other drum that will fit that maybe I can get here? When I mention Pinzgauer at any shop down here they all tilt their heads and laugh..To be expected. This 710 Is perfect for my needs here so I will fight tooth and nail annually to get it to pass inspection. Thanks again for all the help ..
- Hotzenplotz
junglefever
the standard lining for the shoes is 6mm part # 7101364931-1, for machined drums there is a 7 mm version with # 7101364936
additional questions:
- did you replace the rubber hose in front of the generator fan ?
- did you check the pressure at the three way connector next to the rear axle ?
Albert
Albert
- Hotzenplotz
this thread has fallen asleep. It is safe to assume the issue is fixed.
would you mind sharing details ?
Albert
Albert
Hello....I am waking up the sleeping thread... Sorry for the silence. I am in the jungle in Costa Rica doing wildlife research and have limited access to internet connection. I failed at the inspection place so many times dealing with the brakes that I had to give up for now and only drive late at night to avoid the roving police stops looking for the likes of me. This issue has been very frustrating to say the least. On one of the attempts at inspection I backed off the front shoes and cranked down on the rears trying to get more braking power to the rears but it still failed. I tried bringing all shoes up till they were slightly dragging and failed again. Rears always weak and uneven side to side. The Pinz is our up on rollers and a computer analyzes the braking of each wheel and compares them. All have to be within 7% I think. Clearly I failed miserably. The only other suggestion from helpful folks on the forum was perhaps a valve in the brake line near the master is bad. I am considering swapping the front one for the rear one just to see what happens. Sadly I cannot get parts down here unless I carry them myself so that may have to wait until October when I return. Sure would like to solve this issue.
Hello Hotzenplotz,
I finally got around to getting a photo of my master to see what I have for valves that might be wrong. Any way to tell which way they are supposed to go? And should there be two stacked on each line. Assuming that is what those are in the photo I attached. [attachment=0]IMG_3559.JPG[/attachment]
- IMG_3559.JPG (1.94 MiB) Viewed 5586 times
- Hotzenplotz
I took a pic of mine
looks quite identical
Albert
Albert
Should we not first look at some basics:
The Pinzgauer is equipped with an ATE tandem brake cylinder that contains two pistons. When the brake pedal is depressed, the front piston (nearest to the booster), supplies fluid to the rear wheel cylinders and hydraulically depresses the rear piston to supply fluid to the front brakes.
Were a front brake pipe/hose to fail, the rear piston will bottom in the cylinder but the front piston will still supply fluid to the rear brakes. In the case of a rear pipe/hose failure, the front piston will bottom against the rear piston and mechanically depress it to supply fluid to the front brakes.
Brake drums have maximum diameter sizes for safety reasons and it makes sense to remove as little as possible. The relined shoes are then ground to a radius that is just smaller than that drum’s specific diameter. It is thus important that brake shoes are correctly paired with their drums if they do not all have the same diameter. Was the Jungle brake shop knowledgeable about this? Brake linings also come with different coefficients of friction thus have them all relined at the same time.
If all the above has been correctly done we should focus on the next point:
Modern brake systems have proportional valves so that the front brakes are actuated first to prevent skidding (lock-up). This is achieved by a valve that will only allow fluid to flow through above a certain pressure. Load sensing valves, on the rear body, do the same by varying the pressure allowed through to the rear brakes depending on the vehicle's load.
I had a look at the Austrian drawing that Albert supplied but did not clearly see valves however group 07-05 shows item 35 that I do not know what its function is as I only have the illustration without the legend. Pcolette earlier mentioned static pressure valves part # 7103366220 that had been installed backwards and preventing the flow of brake fluid.
Albert can you clarify what this is and why are there two of them as shown in your and Jungle Fever’s photos?
