Ive searched and can not find wheel stud deminsion/thread
NEWFISHER
Post by NEWFISHER »
Having wheels built and my Pinz isn't here yet...grrrr. Trail Ready needs to know the stud size and the thread pitch, I'm coming up empty with searches. Can anyone verify this for me please.
Jon
EDIT: verified the size with 2 well known sources.... M14 x 1.5
leaving this for future search
Re: Ive searched and can not find wheel stud deminsion/threa
On-line DOC's here http://www.exurbis.com/2015/04/document ... pinzgauer/
See: 4.6-Group-6, pg. 2 & 3, M14x1.5.
GenevaPinz
Post by GenevaPinz »
Always be careful if you're ever shopping for lug nuts, 1.5 is not the standard thread for M14.
Jan
'72 Pinzgauer 710M
NEWFISHER
Post by NEWFISHER »
Thanks guys!
ako
Post by ako »
GenevaPinz wrote:Always be careful if you're ever shopping for lug nuts, 1.5 is not the standard thread for M14.
A 'standard' M14 pitch is M14 x 2, a fine thread is M14 x 1.5.
Fine threads in metric are not used much in industrial situations, more common in automotive. :wink:
ako
Post by ako »
Also, as per this thread, the standard wheel nuts are conical, not tapered. Be sure to use the correct nuts for whatever your wheel builder is making.
http://real4x4forums.com/PinzgauerBBS/v ... d&start=15
The original lug nuts are "ball" seat type - not conical - or tapered. Same as used on older VW and Porsche cars.
NEWFISHER
Post by NEWFISHER »
Lug nuts will be 14mx1.5 and tapered to fit the tapered aftermarket wheels. I will be keeping the ball seat oem lug nuts for the oem wheels.
Vince,
Perhaps this bit of information can get added to the sticky thread about lug nuts? It seems to fit in with that advice.
It'd be best if someone could post a summary of the info you are talking about, in a new post, to that thread so we don't stack more threads up there.
