The Portal Hub: All things Pinzgauer, Haflinger, Volvo 303 and more.
From Vince Sweeney: You have arrived at the original "Real 4x4's" Forums, founded in 1999.
The forum isn't free for me to keep up. Donations accepted securely with Paypal.
View unanswered posts | View active topics It is currently Sun Jan 21, 2018 6:07 am
Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 How to jack up a 712M when I want to remove 2 tires ?
Author Message
Post Re: How to jack up a 712M when I want to remove 2 tires ?
I posted a couple of pictures and comments over in the "Owner builds, customizations & accessories" section for those who are interested.
Mon Feb 15, 2016 8:47 pm
Profile
Gents,
Thanks very much for replying !
I usually get notice someone has replied, but not this time, so late in responding.
The powder-coat is sandblasting first, then zinc covered to prevent rust, then a coat of special paint applied electronically and baked on at 350 degrees celcius.
The advantage is that you can drive through anything and have it come off with a little water. The lugs are left as they are - blackish - I have not seen them rust yet...
My main worry is to have the front or back end jacked up and when the wheels come off the ground, that it would be pretty unstable, being only supported on the differential box.
I certainly won't climb in... I think I will just start with two wheels, front or back and a piece of wood to prevent damage to the diff-box
Thanks again for the replies
Jules
_________________
Pinz of rock - 710M / 1975 (Austrian Army)
Tue Feb 16, 2016 5:54 am
Profile YIM
2 -5 ton axle stands were my first Pinz related upgrade for my shop. Better safe than sorry, They can fit close enough to the standard jack to remove it safely.
Tue Feb 16, 2016 7:12 am
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
