View unanswered posts | View active topics It is currently Tue Feb 21, 2017 3:50 am
Reply to topic  [ 13 posts ]
 raise the back of a 712......
Author Message
Post raise the back of a 712......
need to raise about 2 or 3 inches the rear suspensiĆ³n on my 712 to level it..... what is the best way to go?. removing the leaf springs is as easy as it looks???can i add shims to the leafsprings ends??? ,re-shape them?? thank in advance!!!...........
_________________
1985 710MS
1985 712MK
Sun Jul 17, 2016 6:08 pm
Profile
Post Re: raise the back of a 712......
what have you done to your truck to require the rear suspension to be lifted? It is usually just the opposite.
_________________
Sun Jul 17, 2016 6:43 pm
Profile
is equiped as a motorhome, and it has more weight in the back i believe......but the front end is higher.....
_________________
1985 710MS
1985 712MK
Mon Jul 18, 2016 6:53 am
Profile
A good truck spring shop should be able to make and install a helper spring to the rear leaf spring set-up. Only raising the truck will not increase load handling capabilities. Overloaded springs are more likely to break. A helper or extra leaf should solve your problem. It may be also worth having the truck weighed to ensure you are not exceeding its recommended GVW.
Good luck.
Cheers, Clive
Mon Jul 18, 2016 8:49 am
Profile
I'd tend to agree with Clive. The only time I even got the rear axles horizontal was when my truck was loaded down with oak planks, and it wasn't particularly low in the rear end. How heavy is the truck, gross?
Mon Jul 18, 2016 11:33 am
Profile
i have no idea, but is not that heavy,,, i just think they sag due to age....or the front spring are from a newer truck??? is my front end higher tan normal??? wondering :( :(
_________________
1985 710MS
1985 712MK
Mon Jul 18, 2016 12:04 pm
Profile
A picture is worth a thousand words...
_________________
Real 4x4 Facebook: https://www.facebook.com/real4x4s
Mon Jul 18, 2016 12:18 pm
Profile WWW
Look how the tires are setting on the ground, if loaded and the axles are parallel with the ground, that is where you want them. The tires are where they make full contact and even wear. The nose being high might be from your load being too far back or the front springs being too high of capacity for the load balance.
If you have a negative angle to the rear axle camber, check that you don't have a broken spring pack or you are overloaded.
My 718K sits a bit nose high empty. But is basically new and untarnished. :mrgreen:
_________________
Mon Jul 18, 2016 12:51 pm
Profile
like David Dunn says... my front axle has positive camber, while my rear axles are almost zero camber or a Little positive but no negative camber at the back,,,,its 1 1/2 inch difference in height front to back.... :?: :?: Image
_________________
1985 710MS
1985 712MK
Mon Jul 18, 2016 4:22 pm
Profile
I would not touch the back.
Look under the front at the pin under the front springs, those are available in shorter lengths to level the ride.
Other choices are different (lighter) springs to bring the nose down , IF it really bothers you.
Personally, I'd throw the passengers that will be in it to see if the front settles a little more and see how it rides. Plus all the gear you'll be carrying. Ultimately, it how the truck performs and handles that matters.
I don't know how much and where your gear is, but moving heavier gear forward may help to put more weight on the front axle (but doubt it would be much).
I also just notice you have dual tanks, fill them both, that is more weight towards the front.
I think that you'll be liking new shocks over playing with the suspension. And if anyone notices the "nose up", tell them your Pinz is a proud girl and thinks she better than anyone else. :mrgreen:
Very pretty truck.
_________________
Mon Jul 18, 2016 4:57 pm
Profile
These are 2 pics of GG from the side.
In the first pic, the drawbar of the canon had very little weight on the pintle , and didn't change the rake of the truck.
And for some reason, in the 2nd pic, it looks "nose down". :?
Drive your truck and enjoy it.... no one can measure a 1 1/2" difference front to rear at 25mph. :mrgreen:
_________________
Mon Jul 18, 2016 5:18 pm
Profile
thanks guys.... i just leave it alone the way it is..i also want to add a winch and more stuff to the front bumper eventually.... nobody ever notice that but me..... besides .. it looks faster on the road!!! :D :D
_________________
1985 710MS
1985 712MK
Mon Jul 18, 2016 5:26 pm
Profile
adding the front bumper and winch will pull it down
_________________
(2) 1968 Haflingers One For Sale
1979 Mini Cooper Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Current Company Cars
2016 Flex
2017 F-150
Mon Jul 18, 2016 5:55 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
