Camber on my 712 .
Posted: Wed Aug 03, 2016 2:08 pm
by darstar
The front wheels tilt inward quite a bit and does make a strong track on a gravel road. Is this normal ? MY TIRE GUY SAYS IT CAN'T BE AND WON,T PUT ON NEW RUBBER UNTIL I GET IT FIXED....NOT SURE IF ANYTHING IS WRONG OR NOT ? Anyone help on this. Its my first unit and I know very little about it. The manual is mostly in German , so little help.
Re: Camber on my 712 .
Posted: Wed Aug 03, 2016 2:15 pm
by VinceAtReal4x4s
Can you post a pic or two that shows what you mean? What did you mean by "makes a strong track.."?
Posted: Wed Aug 03, 2016 3:11 pm
by undysworld
Sounds normal. Mine are basically the same. Unless it's loaded, all the tires are tilted outwards at top, due to the suspension design.
I rotated them often, and ran my tires until the outside edges are worn down, then I remounted them with the opposite sides outward and run them down too.
Maybe I got twice the mileage that way?
Posted: Wed Aug 03, 2016 5:43 pm
by audiocontr
need a new tire guy
Posted: Thu Aug 04, 2016 4:18 am
by 4x4Pinz
pics would be nice to see just exactly what you are dealing with.
