View unanswered posts | View active topics It is currently Sun Jan 21, 2018 6:13 am
Reply to topic  [ 5 posts ]
 OEM Hydraulic Jack leaking
Author Message
Post OEM Hydraulic Jack leaking
We've had our 71 710M for a few weeks now. The OEM jack has been behind the back seat with no leaks. I used it today to put one new tire on and it started leaking from the valve and a little around the base. I didn't get the jack handle with the vehicle so I used some pliers to close the valve, maybe I closed it too tight?
I absolutely love the OEM jack and want to fix it and have it with me in the Pinz to use.
Anyone fixed their OEM jack leaks? Suggestions on how to get parts required, etc.?
_________________
1971 Pinzgauer M710, all stock including 245-16 Maloya tires, taken off and stored for show
Thu Nov 17, 2016 6:38 pm
Profile
Post Re: OEM Hydraulic Jack leaking
I've had 3 of them rebuilt by this outfit: https://www.phjjacks.com
I just shipped the jacks to them and requested that they rebuild as needed. I have nothing to compare them to but I've been happy with the results.
As I recall the jacks were made by Weber in Germany.
_________________
'72 Swiss 710M
Thu Nov 17, 2016 7:39 pm
Profile
You're fortunate that the you caught the leak early. When I got my 712 the jack had been leaking in the cab for a long time. Quite the mess.
Sat Nov 19, 2016 2:17 pm
Profile
My jack was leaking from the valve that relieves pressure on the jack. Since that was the only leak I decided to try to fix it myself. I machined a piece of Delrin to fit over the valve stem which will compress rubber seal. So far no more leaks.
Tue Feb 28, 2017 3:35 pm
Profile
Ditto, x3
_________________
289 County Road 1673
Mount Pleasant, TX. 75455
(903) 717-4018 shop
(951) 765-7224 cell
74 710m and (1) pinz trailer
Fri Mar 03, 2017 8:22 am
Profile WWW
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
