OEM Hydraulic Jack leaking
bbolander
Post by bbolander » Thu Nov 17, 2016 6:38 pm
We've had our 71 710M for a few weeks now. The OEM jack has been behind the back seat with no leaks. I used it today to put one new tire on and it started leaking from the valve and a little around the base. I didn't get the jack handle with the vehicle so I used some pliers to close the valve, maybe I closed it too tight?
I absolutely love the OEM jack and want to fix it and have it with me in the Pinz to use.
Anyone fixed their OEM jack leaks? Suggestions on how to get parts required, etc.?
IMG_1191 copy.jpg (528.93 KiB) Viewed 1191 times
Re: OEM Hydraulic Jack leaking
Post by pcolette » Thu Nov 17, 2016 7:39 pm
I've had 3 of them rebuilt by this outfit: https://www.phjjacks.com
I just shipped the jacks to them and requested that they rebuild as needed. I have nothing to compare them to but I've been happy with the results.
As I recall the jacks were made by Weber in Germany.
2002 MB G500 (For Sale)
idstitch
Post by idstitch » Sat Nov 19, 2016 2:17 pm
You're fortunate that the you caught the leak early. When I got my 712 the jack had been leaking in the cab for a long time. Quite the mess.
Sonarman
Post by Sonarman » Tue Feb 28, 2017 3:35 pm
My jack was leaking from the valve that relieves pressure on the jack. Since that was the only leak I decided to try to fix it myself. I machined a piece of Delrin to fit over the valve stem which will compress rubber seal. So far no more leaks.
Andre
Post by Andre » Fri Mar 03, 2017 8:22 am
pcolette wrote:I've had 3 of them rebuilt by this outfit: https://www.phjjacks.com
Ditto, x3
289 County Road 1673
Mount Pleasant, TX. 75455
(903) 717-4018 shop
(951) 765-7224 cell
74 710m and (1) pinz trailer
