Turn Signal Light Coming On With Braking
jrcotner
Post by jrcotner » Wed Mar 08, 2017 1:22 pm
And another thing. Same trip as previous post, but I noticed that occasionally the turn signal light would come on for one blink during braking. I looked through the manual and it only mentions the brake light on the dash as a warning light, nothing about the turn signal light. Brake fluid is topped up and my knees were no where near the turn signal lever. Any ideas?
John Cotner
1946 Willys CJ-2a
Elizabethton, TN
Re: Turn Signal Light Coming On With Braking
Post by Jimm391730 » Wed Mar 08, 2017 4:46 pm
There are a lot of switch contacts and connections within the turn signal/four way flashers/brake light wiring. If the turn signal switch contacts get poor, or if the four-way switch contacts get poor, either can cause a problem. A "one blink" event means there is some sort of contact that changes after one blink. An iffy ground might also appear to do the same, but switch contacts are intended to be made and broken as the switch moves, so I would expect them to be more likely. The four-way switch is easy to open up and clean and grease, but first thing is to "work" the contacts several times and see if you get a change (for better or worse), this will help you to hone in on the problem.
jrcotner
Post by jrcotner » Wed Mar 08, 2017 8:12 pm
Thanks. I'll fiddle with it and see if things change. I'll also check grounds, since I went through some water and may also have some salt corrosion.
John Cotner
1946 Willys CJ-2a
Elizabethton, TN
jrcotner
Post by jrcotner » Fri Mar 10, 2017 4:02 am
I fiddled around a bit, and things seemed to have cleared up. But now the turn signal light blinks once every ten seconds or so just driving down the road.
John Cotner
1946 Willys CJ-2a
Elizabethton, TN
Post by pinzinator » Fri Mar 10, 2017 9:03 am
Your turn signal switch could be junk. The switch out of a 1971 VW Bus works perfectly, Airhead Parts sells them, and even the color codes are the same.
jrcotner
Post by jrcotner » Fri Mar 10, 2017 4:06 pm
Thanks for the tip. I was running out of ideas, so I'll try it out.
John Cotner
1946 Willys CJ-2a
Elizabethton, TN
Brickren
Post by Brickren » Sat Mar 11, 2017 9:12 am
1975 710M
2000 Ural Tourist
Post by pinzinator » Sat Mar 11, 2017 9:33 am
Here's the specific one I bought. It even cancels most of the time, unlike the previous one-
http://www.airheadparts.com/Switch-Turn ... 53-513%20G
Post by pcolette » Sat Mar 11, 2017 1:22 pm
I've used the repro VW unit from Airhead and it works nicely. More recently though I've used the Austrian version of the oem unit and found it to be a better quality for not much more money.
https://www.pinzgauer.com/showdetails.p ... 113860180/
However the wiring on it is intended for use with trucks that have had the red brake light conversion done. Most likely you've already done this?
2002 MB G500 (For Sale)
jrcotner
Post by jrcotner » Sun Mar 12, 2017 6:03 am
Nope, stock tail lights.
John Cotner
1946 Willys CJ-2a
Elizabethton, TN
Brickren
Post by Brickren » Sun Mar 12, 2017 9:49 am
Stock rocks. So, those of us that refuse to convert, what switch do we use?
Sent from my A0001 using Tapatalk
1975 710M
2000 Ural Tourist
Post by pcolette » Sun Mar 12, 2017 10:06 am
I was referring to the brake light wiring modification, not the replacement of the stock tailights.
jrcotner
Post by jrcotner » Mon Mar 27, 2017 4:41 am
Just to follow up, I replaced the flasher with the NAPA part, and it cleared up the turn signal indicator flashing intermittently and when braking. It also isolated the turn signal switch problem. The right turn detent is worn and won't maintain a signal. I'll replace with the VW unit. Thanks for all of your help.
John Cotner
1946 Willys CJ-2a
Elizabethton, TN
dbixby001
Post by dbixby001 » Thu Feb 08, 2018 9:57 pm
I am looking for this switch, but the links in this post do not work for me. Can someone help me find where I can get the Turn Signal switch referenced?
Post by pcolette » Thu Feb 08, 2018 10:39 pm
Here's a fresh link to the Austrian turn signal switch at SAV: https://www.pinzgauer.com/showdetails.p ... 7113860180
It does require the wiring modification of the tail lights so that the brake lights are red.
