Flushing Hydraulics
SAM. C.
Flushing Hydraulics
Post by SAM. C. » Sat Jan 20, 2018 5:39 am
Hi All
I am going to flush my whole hydraulic system and replace new fluid. I read somewhere to use spirit to do this prior to re-filling. Does this sound like it makes sense? I was thinking methylated spirit what do you think? Or is there some off the shelf product that does this job?
Thanks Chaps
Sam
Re: Flushing Hydraulics
Post by VinceAtReal4x4s » Sat Jan 20, 2018 5:50 am
I've always used only the new fluid to push the old out. You could run into issues with something else in there eating seals, etc. plus you would have a hard time making sure it's all out.
Post by rmel » Sat Jan 20, 2018 6:16 pm
Vince is correct, never use anything other than the recommend DOT 3 brake fluid to flush the system.
One recommendation since you do plan on a complete flush, pump all the old fluid out first, then add
the new fluid that way you know all the old is indeed out.
Rescue Pinz: 73' 712M
Post by Jimm391730 » Sat Jan 20, 2018 9:09 pm
Be sure to clean out the reservoirs; not only of the old fluid, but often there can be a substantial amount of "sludge" in the bottom. You don't want that getting into the new fluid.
SAM. C.
Post by SAM. C. » Wed Jan 24, 2018 9:39 am
Thanks guys. Pretty much my thoughts exactly. When I read it I thought it was a bit strange. Good advice about the reservoirs I will make sure I check them.
Thanks again
