front coil spings...
Posted: Wed Mar 13, 2019 2:20 pm
by waterdog
hello .. does anybody know if a TD Front coil springs are a direct replacement for a 710 ????
any experiences???
Re: front coil spings...
Posted: Wed Mar 13, 2019 3:05 pm
They each use different part numbers.
7101543921 for Series 1 (Gas), 7581540421 for Series 2 (TD)
Posted: Thu Mar 14, 2019 12:21 am
by David Dunn
TD front springs will fit the 710/12, BUT the 716/18 are handling more weight in front with the diesel , auto box (in many cases) plus the radiator and additional cooling system weight. The TD's front suspension had more spring/support pins combos because of additional accessories ( like winch, etc..)
Attached are the factory spring/support pins available from the factory
