Torque for Transit Wheels?
Posted: Tue Apr 09, 2019 10:54 pm
by AZ_Mike
Ford spec is 100 lb-ft (136 Nm) for those wheels. Anyone have issues tightening to 200 Nm (147 lb-ft) Pinz specs? I don't want to bend the raised nut seats.
Re: Torque for Transit Wheels?
Posted: Tue Apr 09, 2019 11:17 pm
by rmel
Recommendation even for the stock Pinz bolts is to back down to 100 ft-lbs.
However, after a 30 mile drive re-torque to be safe.
Posted: Wed Apr 10, 2019 4:07 pm
by AZ_Mike
Thanks. I got bad info. I'd be suprised if my hand "German Torque" (goodentight) is under 100 ;)
Posted: Wed Apr 10, 2019 4:23 pm
by AZ_Mike
I found some technical info by year and model and some of the heavier and higher horse power Transport models use 204 Nm (150 lb-ft).
Posted: Wed Apr 10, 2019 10:00 pm
by rmel
It's all a matter of material science. Pinz stud and nut is M14 x 1.5mm 8.8 hardness.
Standard recommended max torque is 100 ft-lbs dry, 80 ft-lbs lubricated (anti-seize).
If the studs are 12.9 then your up in the range of 150 ft-lbs (dry). Puch pushed several
bolts beyond the max. e.g. Limit strap and shock bolts. But all other bolts are W/I
recommended limits -- go figure ://
Check your bolt size, harness and thread prep.
Posted: Wed Apr 10, 2019 10:10 pm
by 4x4Pinz
it also should be noted that some folks who thought tighter was better had to buy new rims. You can search and see where they cracked the rims at the lug holes from being too tight and also using the wrong lug nuts.
Posted: Thu May 02, 2019 7:20 pm
by AZ_Mike
I'm at 130 ft lb and I'm going ti stick with it. Had to retorque twice because the Transit wheels have powder coat in the nut seats.
