Brake question
Brake question
Would a leak in the hose from the intake manifold to the brake booster have any effect on the travel of the brake pedal? Or could the plastic valve in that hose be a problem?
We've bled the brakes 3 times and on first brake application the pedal still sinks way down but then is fine after that. Braking is okay but the pedal travel is a problem.
Hopefully it's not rebuild time for the master cylinder :(
Post by Jim LaGuardia »
Try adjusting the shoes, they are not self adjusting :wink:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
David Dunn
Post by David Dunn »
Brake adjustment would be the first thing to check... if it still require pumping, check all the rubber hoses for swelling or ballooning, and lastly a bad check valve in the Master cylinder. Other symptems will tell other faults.
But SH ! Don't tell anyone... I didn't say a thing :wink:
ABSOLUTSECURITY
Post by ABSOLUTSECURITY »
[quote=
But SH ! Don't tell anyone... I didn't say a thing :wink:[/quote]
LOL!!!!!!!!!!!! :shock: :D :shock:
G
sdibaja
Post by sdibaja »
pcolette: to answer your question, yes. But the effect would be a loss of assist in applying pressure... if there are no leaks in the vacuum hoses then you could/should feel the pedal go down more easily.
Jim and David are steering you in the right path
Peter Ehlert
34°37'N 112°19'W & 31°43'N 116°39'W
1963 Unimog 404 Doka ragtop
Thanks guys. I completely forgot about adjusting the brakes :oops:
Dang it's hell getting old - too much to remember! I should have learned less :D
