How do i tell when brakes need adj vs bleeding vs rebuilt MC
Posted: Wed Oct 13, 2010 10:22 am
One of the benefits of having two pinzgauers is comparing performance. You can determine whats a normal trait of these vehicles vs an issue. Case in point: My 712 braking is horrific compared to my 710. There is tremendously more pedal travel plus less bite.
This leads me to my questions: Am i correct in my logic below?
If pedal travel is extensive, adjust brakes.
CHECK. (Adjusted front and back, backing off 4 clicks (5 on the inners). Is this too many?)
If adjusting brakes yields minor gains, bleed brakes.
CHECK. (Not the easiest job to accomplish with one person. I may want to recheck one of these days but im pretty sure I did all 6 wheels correctly using a vaccum brake kit from HF)
If neither yield significant gains, rebuild master cyl?
A double pump does not result in significant increase of braking. What does this mean? Rebuild is needed or go back and readjust?
And while i have your attention, would bleeding the clutch system raise the engagement point on the pedal? The 712 pedal is less firm than the 710.
