Long bleed nipple?
spandit
Long bleed nipple?
Post by spandit »
My rear left-hand brake bleed nipple (M6x1.00) is rounded and I have to undo it with mole-grips. However, when I took it out to clean it, I notice it's about 50mm long - looks like someone has welded a section in. Is this standard? If not, how does one normally access the nipple?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
I use a deep socket. Run the tubing through the socket and use a vise-grip (adj. locking pliers) to turn the socket. Ta-da.
Malahki
Post by Malahki »
Nice trick!!
spandit
Post by spandit »
Just won some of these on eBay:
Should do the job nicely - pity I can't find any more online
Robin
Pinzgauer 710K
MegaJolt ignition
