Tire similiar in size to original Maloyas?
Posted: Tue Mar 08, 2011 6:13 pm
by Hersir
Would a BFG Mud Terrain KM2 LT235/85R16 be equivalent in size to the original Maloya tires used by the Swiss Army? I understand the overall diameter of the LT235/85R16's is 32 inches. Would these be good tires for mild to moderate off-roading with some local highway time between home and dirt?
Thanks.
Re: Tire similiar in size to original Maloyas?
Posted: Tue Mar 08, 2011 7:49 pm
You can easily put 265 85 16 BFG's, this will better your highway speeds and do well for most off roading. I have the 255 85 16 Maxxis Bighorns on my 710M, they are similar to the BFG's but less expensive.
Posted: Wed Mar 09, 2011 3:05 am
by GenevaPinz
If I remember well, the 235/85 size is slightly smaller than the original Maloyas and the 255/85 size is slightly bigger, both in diameter and width (Maloyas being about 245 in width).
Posted: Wed Mar 09, 2011 5:55 am
by stiffler4444
I will need to verify, but last summer I believe I put 265/75/16 goodyears on mine and they are wider and about the same height as the Maloya....great size at any rate
Posted: Mon Mar 26, 2012 12:30 pm
by berger
Hey Guys.
I found this thread because I am curious about tire sizes....mainly because I cannot get into my garage with the inflated BFG A/T 285/75/R16
. I found a used set of nice tires in 235/85/R16 and I was wondering how they will affect highway speed? After calculations, they are 1" smaller than the 285s....
Will 285s fit on stock rims? I read something about 285s being on widened rims....and I couldn't tell you if mine are widened...
Posted: Mon Mar 26, 2012 2:18 pm
by CentAr712
I believe I read somewhere on here that the stock Maloyas are 245/75; if they in fact have a 75% aspect ratio, then a 235/85 will actually be a little bigger diameter even though they are 10mm narrower. From what I've researched, the 235/85 should have the most similar size in general to the stock Maloyas. I don't think I've seen any new tires available in 245, just 235 and 255. I think I may go with the 235 BFG/MT's personally.
Posted: Tue Mar 27, 2012 5:00 am
by berger
In case anyone is interested, this tire sizing calculator is great. It lets you visualize both sets of tire sizes on top of each other in a side and end view...
http://www.miata.net/garage/tirecalc.html
Posted: Tue Mar 27, 2012 10:20 am
by Stekay
I've built a pretty good tire size / RPM calculator in EXCEL. Unfortunately you can't attach a file with a .xls extention. PM me if you need it with an e-mail address and i'll sent it to you.
Posted: Tue Mar 27, 2012 11:24 am
by CentAr712
This thread got me interested in pricing some tires and as it turns out, they do make the BFG/MT's in 245; but they are more expensive than the 255's or 235's.
Posted: Thu Mar 29, 2012 2:44 am
by ScottishPinz
Greenway 235/85R16 MACHO (not produced any more) shown here next to the Mayola's.
Posted: Thu Mar 29, 2012 6:04 am
by stiffler4444
265/75 goodyear wranglers are near exact size....
Posted: Thu Mar 29, 2012 4:12 pm
by VinceAtReal4x4s
255/85's feel the best to me.
Posted: Thu Mar 29, 2012 5:44 pm
by berger
Posted: Thu Mar 29, 2012 6:04 pm
by cowetadirtfarmer
I put BFG km2 mud terrain 265/75/16 on about a month ago. They are just a little bigger than the maloyas.
Tires made a huge difference over the original maloyas.
Posted: Mon Aug 27, 2012 12:39 pm
by Hersir
It's a year and a half later since I started this thread and I want to thank everyone for the feedback and photos. One of my biggest considerations in replacing my tires is squeezing into a residential garage. Currently, I have the BFG M/T 285/75/16 which are 33.1" in diameter. I've saved up some money and will be replacing them with the same tire but size down to 265/75/16. This will give me 1.2" of additional clearance which should be just enough and they're pretty close to the original tire size.
Many thanks again.
