aftermarket shocks????
waterdog
Paraguay
Post by waterdog »
can you guys tell me what kind of shocks would be a good upgrade or replacement for OE shocks?? for a 710, does anybody know specs on factory ones??? thanks :?: :?:
1985 710MS
1985 712MK
Profpinz
Re: aftermarket shocks????
Post by Profpinz »
I run Koni's ....couldn't tell you the part number off hand (i'd have to look it up on the shocker) but I took a factory original unit into a Koni distributor and after a few pertinant questions about the vehicle he matched it up.
http://www.ozpinz.com
I use the Doetsch shocks that they made for the Pinz. I bought them from Scott at EI: http://www.expedition-imports.com/produ ... 10712.html
I'm very happy with the fit and the ride.
I use the Doetsch shocks made for the Pinz as well. Excellent fit, good ride. Got them from EI.
cruzoropeza
Post by cruzoropeza »
Best bet is go with the once Expedition Import sell they are made for the pinz! I previously got some ranchos and the proplem is that other shocks are valved differently. Whenever I would take a bump too quick it felt like the shock would not return quick enough, I would head a snapping noise switched them back and problem was solved! Good luck
Winter Beater
Post by Winter Beater »
I too have the EI shocks. Easy to install, ride well and not too expensive.
