Steering support loose
NoahDL88
Post by NoahDL88 »
Anybody have any tips or tricks about tightening the inboard end of the steering support bracket on the inside of the cabin, I can't get a wrench on the bottom side and the noise it makes is a little disconcerting.
I think cutting it and putting a new bolt in is a no go as I'll just have the bottom half stuck in instead of the whole thing.
1972 710K
Twin Pinzies
Re: Steering support loose
Post by Twin Pinzies »
You can't get a wrench on it? Did you remove the floor pan?
NoahDL88
Post by NoahDL88 »
I removed the floor pan but there isn't much room at all, the piece it's bolted through doesn't leave enough room for even a stubby wrench.
1972 710K
StuartL
Post by StuartL »
I haven't looked at this bit but I found with the handbrake housing a ring spanner was the only tool I could get onto certain nuts.
UK Virtual Assistant services in English: http://www.seekingserenity.co.uk/
