Length of OEM limit straps?
Posted: Sat Jul 27, 2013 10:06 pm
by Twin Pinzies
I was sick of blowing through stock limit straps ($159 each) years ago so I converted to custom made nylon versions ($34 each). I'm having some new custom length nylon straps made (from OK Offroad) to replace the current worn out ones.
*Nylon limit straps need to be made slightly shorter to allow for the stretch that occurs during break-in.
My question is what is the perfect length? Here are some of my measurements:
The length of the axle drop (with the strut and limit strap removed) = 19.25"
The length of the fully extended Rancho strut (made for the Pinzgauer) = 21.25"
The same distance when sitting on the ground under it's own (empty) weight = 17.25"
Am I right to assume that the 17.5" nylon limit straps that I'm currently running are still the best way to go? It seems really odd that the Pinz is designed to have almost NO axle extension! ?
Re: Length of OEM limit straps?
Posted: Sat Jul 27, 2013 10:59 pm
by 4x4Pinz
we have been running 18" limit straps for several years on a number of our trucks. Not one failure with the nylon strap and no ill effects in the suspension systems have been noted. When the straps hit the max limit it seems much softer then the original straps. We just run two at each location with a spacer. The 18" strap is a stock length so is more cost effective then custom lengths. A new original strap measures real close to 18.25"
Posted: Sat Jul 27, 2013 11:28 pm
Any photos of your set up with them installed? I had thought about the nylon straps years ago but never followed through as my OEM straps
are just fine.
Posted: Sun Jul 28, 2013 9:57 am
by Twin Pinzies
Thanks 4x4Pinz, You just reaffirmed my suspicion that the 18" nylons are the way to go.
I am also running dual nylons all the way around too.
Posted: Sun Jul 28, 2013 6:30 pm
by 4x4Pinz
Here is a pic of the limit straps installed, yes they are dirty I do use my truck once in a while
![Wink :wink:](./images/smilies/icon_wink.gif)
Posted: Sun Jul 28, 2013 7:33 pm
by berger
At what point do they need to be replaced? I have noticed that one or two strands are frayed on one strap, but nothing to serious.
Sent from my Mobile
Posted: Sun Jul 28, 2013 7:40 pm
by compunerdy
4x4pinz.. what brand are you using?
Posted: Sun Jul 28, 2013 10:11 pm
by 4x4Pinz
Have had these straps on for a few years now. Mark's old 712 has had them on at least a year longer then mine and while his truck did not see as much trail time the straps look great. the tires (285 16 75r on widened rims) rub them when at full suspension compression and making hard turns. The reason I chose to run two was in the event one broke I would still have time to get it replaced without concern for suspension damage. When the single originals would fail I would take the truck off the trail to prevent any damage to the running gear.
the ones I have on my 712 (in photo) are from SDHQ but they are similar to the ones available at most quality offroad centers. All the rock buggies use them to limit their travel.
Posted: Wed Jul 31, 2013 12:09 pm
by michaelh712
Mike,
can you share information about the spacers and perhaps where to obtain them? Do I need longer bolts? I have the straps and it's time to install them.
thanks,
Michael
Posted: Wed Jul 31, 2013 5:25 pm
by 4x4Pinz
I used 3/4 black pipe, being a plumber has its advantages, cut to length to fit between the two straps. I used the original bolts. The strap brackets are only about 1/4' and the original straps are about 1 1/2 inch so the difference had to be made up.
Posted: Wed Jul 31, 2013 9:23 pm
by michaelh712
Thanks Mike,
this helps.
Posted: Sat Jun 03, 2017 8:56 am
by cronapress
I bought 4 nylon straps from OK Offroad about 3 years ago for the rear axle of my 712. Very pleased with them. The original straps on the centre axle went twang a couple of weeks ago whilst fording a river that had a hidden hole in the bed, which seemed to equal the depth of the Mariana Trench (?)
![Shocked :shock:](./images/smilies/icon_eek.gif)
I bought another 4 for that axle. Re-used the centre bushes after cutting to right length. The folks at OK Offroad were again really helpful and dispatched straps pronto. Highly recommended !!
Posted: Sat Jun 03, 2017 6:50 pm
by 4x4Pinz
I have been running these same ones and have had no issues. I played with the heavier springs and have since replaced the front springs with stock. Still no issues with the straps. One rubbed a tire once somewhere along the trail and has a slight fraying mark from that contact but other then that they look like they did when they went in only a little dirtier now.
