The Portal Hub: All things Pinzgauer, Haflinger, Volvo 303 and more.
From Vince Sweeney: You have arrived at the original "Real 4x4's" Forums, founded in 1999.
The forum isn't free for me to keep up. Donations accepted securely with Paypal.
View unanswered posts | View active topics It is currently Sun Jan 21, 2018 6:09 am
Reply to topic  [ 7 posts ]
 Drive with one 712 wheel off the ground?
Author Message
Post Drive with one 712 wheel off the ground?
Friends,
Is there a way to drive a 712 with one of the four rear wheels off the ground?
Like using a come-along to winch the 1/2 shaft upward?
This would be an expedient way to survive a flat if you had run out of spares.
_________________
MaxF
1973 712m Reno NV USA
"The difference between theory and practice is much greater in practice than it is in theory"
Wed Sep 24, 2014 12:47 pm
Profile
Post Re: Drive with on 712 wheel off the ground?
Search for the red bull truck a few years back. A come along can be used to pull the axle up for towing. I would not plan to drive it.
_________________
(2) 1968 Haflingers 1 For Sale
1978 GMC Palm Beach
1979 Mini Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Company Cars
2017 MKT
2018 F-150
Wed Sep 24, 2014 12:58 pm
Profile
could you remove 1 rear wheel (say the middle one) and drive a 712?
_________________
72 Pathfinder
75 710M 2.7i
94 350GDT
96 350GDT Worker
Wed Sep 24, 2014 2:06 pm
Profile
I know that if you remove one wheel from the rear of a 712 the drum just barely clears the ground (obviously this depends on your tire size). I've used this method on a dynamometer during testing. I would not "drive" it this way -- a rock or bump could shatter the drum and/or damage the aluminum hub casting.
On the other hand, I once had a flat on the mid axle and did not realize it; I probably drove several miles before I was flagged down. It did not do the tire any good, but I probably could have driven much further (having at least the wheel on will protect the drum and hub from most damage). This event caused me to get a tire pressure monitoring system, tubeless tires, compressor and plug kit so I can repair most small punctures by realizing the tire pressure is dropping before the tire has been destroyed. Prevention is much easier than changing to the spare (assuming you have a spare to change).
_________________
Wed Sep 24, 2014 2:25 pm
Profile
I know it s crazy thought...But
Yes - that is exactly my question. Lift one off the ground and drive on the other three.
If you removed the wheel and lifted the hub "somehow" - maybe winched it up or something. Maybe it requires a special piece that bolts to the hub with a bearing on it so you can hook to the end of the hub and hold it up out of danger. Hold it up by the gunnel above?
I thought I saw this done in someones Africa travel log. But can't find the reference anymore.
[RedBull PInz search did not yield and good images]
_________________
MaxF
Wed Sep 24, 2014 3:01 pm
Profile
Post Re: Drive with one 712 wheel off the ground?
I realise I am bumping a very old thread. :shock:
But if you really wanted to do this you could jack up one axle, and replace the standard 18" limit strap with a 'spare' 16" limit strap that you have bought just for this purpose.
Still I would prefer to drive with one flat and destroy a relatively cheap tire rather than a portal hub.
Tue Feb 10, 2015 12:24 pm
Profile
Good point - shredding the flat tire and destroying the wheel is a cheaper solution!
_________________
MaxF
Tue Feb 10, 2015 12:34 pm
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
