View unanswered posts | View active topics It is currently Sun Jan 21, 2018 6:18 am
Reply to topic  [ 7 posts ]
 Drive with one 712 wheel off the ground?
Author Message
Post Drive with one 712 wheel off the ground?
Friends,
Is there a way to drive a 712 with one of the four rear wheels off the ground?
Like using a come-along to winch the 1/2 shaft upward?
This would be an expedient way to survive a flat if you had run out of spares.
_________________
MaxF
1973 712m Reno NV USA
"The difference between theory and practice is much greater in practice than it is in theory"
Wed Sep 24, 2014 12:47 pm
Profile
Post Re: Drive with on 712 wheel off the ground?
Search for the red bull truck a few years back. A come along can be used to pull the axle up for towing. I would not plan to drive it.
_________________
(2) 1968 Haflingers 1 For Sale
1978 GMC Palm Beach
1979 Mini Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Company Cars
2017 MKT
2018 F-150
Wed Sep 24, 2014 12:58 pm
Profile
could you remove 1 rear wheel (say the middle one) and drive a 712?
_________________
72 Pathfinder
75 710M 2.7i
94 350GDT
96 350GDT Worker
Wed Sep 24, 2014 2:06 pm
Profile
I know that if you remove one wheel from the rear of a 712 the drum just barely clears the ground (obviously this depends on your tire size). I've used this method on a dynamometer during testing. I would not "drive" it this way -- a rock or bump could shatter the drum and/or damage the aluminum hub casting.
On the other hand, I once had a flat on the mid axle and did not realize it; I probably drove several miles before I was flagged down. It did not do the tire any good, but I probably could have driven much further (having at least the wheel on will protect the drum and hub from most damage). This event caused me to get a tire pressure monitoring system, tubeless tires, compressor and plug kit so I can repair most small punctures by realizing the tire pressure is dropping before the tire has been destroyed. Prevention is much easier than changing to the spare (assuming you have a spare to change).
_________________
Wed Sep 24, 2014 2:25 pm
Profile
I know it s crazy thought...But
Yes - that is exactly my question. Lift one off the ground and drive on the other three.
If you removed the wheel and lifted the hub "somehow" - maybe winched it up or something. Maybe it requires a special piece that bolts to the hub with a bearing on it so you can hook to the end of the hub and hold it up out of danger. Hold it up by the gunnel above?
I thought I saw this done in someones Africa travel log. But can't find the reference anymore.
[RedBull PInz search did not yield and good images]
_________________
MaxF
Wed Sep 24, 2014 3:01 pm
Profile
Post Re: Drive with one 712 wheel off the ground?
I realise I am bumping a very old thread. :shock:
But if you really wanted to do this you could jack up one axle, and replace the standard 18" limit strap with a 'spare' 16" limit strap that you have bought just for this purpose.
Still I would prefer to drive with one flat and destroy a relatively cheap tire rather than a portal hub.
Tue Feb 10, 2015 12:24 pm
Profile
Good point - shredding the flat tire and destroying the wheel is a cheaper solution!
_________________
MaxF
Tue Feb 10, 2015 12:34 pm
Profile
Who is online
Users browsing this forum: Google Adsense [Bot] and 2 guests
Search for:
Jump to:
