The Portal Hub: All things Pinzgauer, Haflinger, Volvo 303 and more.
From Vince Sweeney: You have arrived at the original "Real 4x4's" Forums, founded in 1999.
The forum isn't free for me to keep up. Donations accepted securely with Paypal.
View unanswered posts | View active topics It is currently Mon Jul 24, 2017 2:36 am
Reply to topic  [ 3 posts ]
 Brake Adjustment
Author Message
Post Brake Adjustment
I removed the rims and placed three lugs on the rotor before accessing the adjustment screw through the hole in the rotor, only problem is that I cannot turn the adjustment screw. What do I do next. The brakes seem fine but I wanted to adjust them while I'm getting new tires placed on the rims. Thank you
Thu Aug 27, 2015 2:36 pm
Profile YIM
Post Re: Brake Adjustment
I guess I'd remove the drum and verify that the adjuster is free to move. Note the direction it moves. Try again.
Remember that one front wheel (IIRC, right side) has adjusters that turn in the opposite direction of the rest of the truck, and that there are two adjusters on each front wheel.
Thu Aug 27, 2015 3:21 pm
Profile
I always pull the adjusters apart when I fit new shoes, as they can seize up given all the mud etc and heat they endure.
Coat the brass "toothed rotator" with a little anti-sieze/copper-coat grease on the outer surface and the internal thread and you should have no trouble adjusting the brakes in the future.
Additionally I have found over the years that the internal thread in the "brass rotator" can get a little damaged especially if the are wound out fully due to worn shoes, so I usually heli-coil them for durability.
It's funny really, because I only replaced all the brakes shoes a few weeks ago and although the adjusters were in good condition and working well, I still did the above for repeated effectiveness.
_________________
http://www.ozpinz.com
Thu Aug 27, 2015 6:26 pm
Profile YIM WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
