rmel wrote:Throwing the baby out with the bath water
...Why give up
the heater for what would be a pretty small volume?
Well, I don't really like babies and I usually take showers, so the heater has to go! The heater is of value, but we don't use it to heat the box, it doesn't heat the cab, and while the gain in storage volume is small, we want it. I'm planning on mounting two plastic jerry cans in he space, and after that there will be loads of space for other stuff. It's a wanted amount of space for me, but it totally agree that for most applications removing the heater probably doesn't make sense.
Haf-e wrote:Removal should be pretty straightforward. Does your truck have two of the gas heaters like the ambulances?
The two lines should be able to be capped off - although finding the correct thread for the cap may be a challenge. There is a webaite for a company called "Belmetric" which stocks all kinds of crazy metric thread plumbing parts BTW. .
...Label all of the connections and take a bunch of photos as you disconnect things - will be valuable later.
Only one heater in my rig, Haf-e. Do you have an ambulance? I think he boxes are nearly identical, with the doors added later on the W models. Where was the second heater hidden? Also, any idea about what the nearly cylindrical indentation high in he box behind the driver? O2 tank storage? Also, I think I responded to you on our website.
Haf-e wrote:That is a really tiny woodstove - but you really need to have some thermal barrier behind it and to the sides - it calls for 20 inches of clearance to any combustable surfaces - but only 2.5 inches with a barrier.
...Don't want to hear you melted you Pinzgauer!
I love our tiny wood stove. We have temporary thermal barriers behind and beside the stove. No joke, the barrier is a 0.30$ disposable cookie tray from a dollar store. I just lean it against the stove. I will eventually build a barrier that incorporates an air barrier. In addition to a barrier on the wall, I'm also planning on purchasing a hinged grease shield, sometimes used in stovetop cooking applications to reduce grease splatter. The will add another layer of heat reflection, AND we will be able to use the shield outside to reduce wind when cooking on our propane cook top. The entire kitchen is outside the driver's side. Multiple uses for everything!
Also, yeah, Cubic Mini Woodstoves sells a wal mount kit for installing my woodstove on a vertical surface, because mounting items in small spaces can be tough, and boat cabins (the intended application) have real limits floor space. The wall mount is just a folded piece of steel, but cuts the distance to combustibles down like crazy. You can essentially bolt the stove to a wooden wall. So yeah, it needs just a little shielding, but it definitely needs a shield.
Lastly, we have since wrapped the stove pipe in fiberglass header/exhaust insulation, and then wrapped that in heat tape. It has drastically reduced the surface temp of the stove pipe, and I think it's helping reduce creosote buildup as well.
