View unanswered posts | View active topics It is currently Sun Jan 21, 2018 6:12 am
Reply to topic  [ 10 posts ]
 Where would one find an etrack rail?
Author Message
Post Where would one find an etrack rail?
I've searched the usual places with no luck. Any leads?
Sun Jun 11, 2017 5:10 pm
Profile
Post Re: Where would one find an etrack rail?
http://www.uscargocontrol.com/Van-Trail ... oCDInw_wcB
_________________
'72 Swiss 710M
Sun Jun 11, 2017 5:25 pm
Profile
https://www.mcmaster.com/#e-tracks/=1813qc9
_________________
Sun Jun 11, 2017 9:02 pm
Profile
Just my opinion here but I would not use E-Track.
I know many have and do but the way 99% of it is installed is incorrect.
Only Scott at EI has installed it correctly from what I have seen - that means running 2 significant backing L channels and then drilling it every 2" to mount the E-Track.
viewtopic.php?f=17&t=7541&hilit=track
Having 6-8 bolts 3-4ft apart is not going to do it and is not how E-Track was designed to work.
With that said, I chose to use L-Track like they use on planes for the seats and on buses to strap down wheelchairs.
Not saying this is what you should do but it is better than mounting E-Track incorrectly!
Here are some pictures of how I had Andre install it:
Runs all around the outside edge of the side boards and is screwed into the bed every 5"
Each double seat-belt fitting has a WLL of 1,333 LBS and Break Strength of 4,000 LBS
Also runs around the rear where I can store extra attachment points
Standard use is obviously for seat belts.
The way I designed it also allows me to remove the side boards to create a flat bed pickup and still be able to reinstall the L-Track for tie down points.
_________________
72 Pathfinder
75 710M 2.7i
94 350GDT
96 350GDT Worker
Mon Jun 12, 2017 10:43 am
Profile
Exactly. I used 1" square steel tubing as the structural supports for the E-Track. My usage is 98% for passenger seatbelts and only the occasional use for cargo tie-downs. I used grade 8 bolts to secure everything; no point in using cheap hardware when lives may be at stake.
_________________
Mon Jun 12, 2017 2:04 pm
Profile
Odd trivia: I recall from my fireman days at vehicle rescue classes that seatbelts were generally rated at 1200 lbs..
Gives some idea on how to rate hardware needs.
_________________
Real 4x4 Facebook: https://www.facebook.com/real4x4s
Tue Jun 13, 2017 2:06 am
Profile WWW
Great info gents! I like the l track idea!
Tue Jun 13, 2017 11:46 am
Profile
Techmogogy,
How did you anchor the L tracks? Was it bolted through before you attached the side panels or attach somehow afterwards?
Thanks!
_________________
75 Swiss 710K
Wed Jun 14, 2017 2:56 pm
Profile
whitesik wrote:
Techmogogy,
Thanks!
They are bolted through ie to remove the side boards you would need to remove the L-Track.
Edit:
More info/pics
Here you can see how they are screwed down
Here it is removed (small pass side rear section)
Nutsert and sideboard hole large enough to account for raised lip
Storage for extra tie downs
I have a drawing somewhere of how I designed it but can't find it.
Andre did the install
_________________
72 Pathfinder
75 710M 2.7i
94 350GDT
96 350GDT Worker
Thu Jun 15, 2017 8:49 am
Profile
Added info above
_________________
72 Pathfinder
75 710M 2.7i
94 350GDT
96 350GDT Worker
Fri Jun 23, 2017 9:45 am
Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
