View unanswered posts | View active topics It is currently Thu Nov 23, 2017 11:24 pm
Reply to topic  [ 4 posts ]
 Do door hinge pins from side doors match front door hinges?
Author Message
Post Do door hinge pins from side doors match front door hinges?
I have a stuck hinge pin in one of my front doors that has resisted all attempts to remove it. I’m about ready to remove via destructive methods, but wanting to have a replacement pin. I haven’t found hinge pins on SAV for the front doors, only the K side doors (part number 7131760151). Does anyone know if this would be the same pin as used in the front door?
_________________
_________________
1977 Austrian 712K
http://www.swpinz.com
Facebook: Southwest Pinzgauer
Tue Nov 14, 2017 7:38 am
Profile
Post Re: Do door hinge pins from side doors match front door hing
Jake
The pins are different
front door pin 7111760461 diameter 8mm length 61,5mm
side door pin 7131760151 diameter 6mm length 45mm
you can find all parts on www.puch.at, the manufacturer's site
_________________
Albert
Tue Nov 14, 2017 9:32 am
Profile
I have found that lots of PB blaster and an air powered impact hammer with pointed bit to be quite effective and actually preserves the pin. However, while out, I would replace them. They are readily available.
_________________
75 710K
New owner
Tue Nov 14, 2017 12:24 pm
Profile
Hotzenplotz, thanks for the information.
Whitesik, I have tried that, but perhaps I need to try again.
_________________
_________________
1977 Austrian 712K
Tue Nov 14, 2017 2:03 pm
Profile
Who is online
Users browsing this forum: Yahoo [Bot] and 2 guests
Search for:
Jump to:
