Sorry if it has been posted, but can manage to find on the forum any advice to split the top from the door bottom part. I removed bolts and screws but it all feels almost like welded. Don't want to bend anything!!
Any advice?
Can't split window assembly from lower part of door
boeing7873
Jerome
CRJ Driver
CRJ Driver
Re: Can't split window assembly from lower part of door
The door top and bottom were sealed together at the factory with a product like thick double-stick tape. Butyl tape perhaps. Over the years it hardens as though the two were welded together. Two or more thin and thick metal putty knives will usually do the trick. Carefully push them into the joint and then continue to slide them toward the front and rear.
boeing7873
Many thanks Paul. What is the standard for reassembling? Put something back in between or just some rubber for quick top removal?
JC
JC
Jerome
CRJ Driver
CRJ Driver
I'm not sure if there is a standard way to do it though I think the sealing tape is still available from SAV and EI. I used waterproof foam tape with adhesive on one side only. 1/16" thick as I recall. https://www.mcmaster.com/#foam-tape/=1crmtj4 (Ultra-Weather-Resistant EPDM Foam Sheets and Strips) Maybe this one: https://www.mcmaster.com/#1566n106/=1crmui4
