Sound Control: General theory and Pinz specific issues.
Fact: Noise causes stress, is a safety hazard, and is a major contributor to driver's fatigue! Controlling noise pollution overall is vital in all of our environments.
I think sound or noise control should be a bigger subject in the exotic 4x4 world since they make more noise then just about any other vehicle. Reducing sound has been sort of a weird hobby of mine, as well as business in the past when building up custom 4x4s for a paying clients. I'm going to share what I know here based on actual experience, training and exposure to professional sound control products and their application in real world scenarios.
Home-grown and random ideas as to what might work to reduce noise often hurt the value of these vehicles, or is not very effective when the costs are weighed out. You will never get to the level of a quiet car or modern SUV but you can at least get half way there, or maybe better.
THE NOT SO GOOD METHODS:
- My own #1 rule is to never use anything that could promote rust or hide a corrosion problem. I think it's very dangerous to use any "bedliner" type of material on horizontal surfaces. I have seen 4x4's ruined this way, starting back in 1992 when I dove deep into the world of older Land Rovers. The Series and Defender models are very loud and some people tried to quiet the interiors this way. All it takes is a microscopic hole to let O2 and H20 do their thing and a few years later, you can be looking at a very costly and time consuming rust repair, or you may even end up with a parts truck! Have you tried removing that stuff before?! Don't make the next guy have to do it because at some point, one day, it will need to come out.
Also, rust often starts on the other side of that piece of metal but you may never know it because the bedliner is covering it up, as well as making it appear to be structurally sound until it's too late. I'd never personally buy a 4x4 with it in the interior without extensive inspections.
- I have seen a lot of "stacking" over the years as well. This is what I refer to when guys will buy a ton of vibration dampening sheets (Dynamat, Rattle Trap, etc) and put it on everything in layers, which is kind of like trying to put out a brush fire with loads of gravel. Along the same lines, rubber mats and vinyl trim have been applied in the same way but none of this usually satisfies. In theory you can get some results from this stuff alone but the final results, weight addition, money spent and risk of hiding corrosion isn't usually worth it.
I'm sorry but it has to be said: Nothing made for the roofs of houses or hotwater heaters is going to be practically effective in managing noise in a 4x4. There is no super cheap way around this problem.
WHAT REALLY WORKS:
The engineers who do this stuff for big auto companies and other industrial applications know how sound propagates in a vehicle and over the years materials and techniques have been developed to deal with this specifically.
Air is what allows sound to move. With no air, there is no sound. All noise control techniques involve blocking air or keeping something from making air move. We generally talk about noise in a car by splitting it up in frequency. Lows, which you feel in your chest and by touching the surfaces that produce them, and you can hear some of them as well (tire rumble, vibrating metal, bass).
The mids, where a lot of voices are and you can hear all of (road noise, wind, engine).
And the highs, which can really annoy you (whistling and gear whine!).
It's proven that some sounds on the extreme low or high can affect you subconsciously even though you can't fully hear them.
1- Vibration dampening This is the foundation of noise control treatment and really helps lessen your lower frequencies. There are a ton of these materials on the market. I did use the Rattle Trap or the Dynamat brands until i saw the light and went professional and now only use Second Skin products. You truly get what you pay for!.
The bad thing about a lot of these products is the marketing. Sound dampening is only one part of the process but they often make it seem like it's all you need; absolutely ridiculous!
Rattle Trap 710K.jpg (117.47 KiB) Viewed 63457 times
Above is a 710K ceiling being treated with Rattle Trap. This was covered over by custom trim panels which were then auto-carpet covered.
These dense sheets of flexible, rubber/asphalt type materials effectively increase the mass of whatever they are applied to and will keep them from vibrating so much, thus reducing the noise they produce and re-transmit. They do the job well but they add weight and hide corrosion. They should not be applied to the floor if at all possible. I use them on ceilings, walls, engine covers, some wheel wells, behind dashes and door skins. Always make sure they are applied over perfectly sealed/painted surfaces and use a heat gun and roller. Total coverage is not needed. Around 30-50% coverage is the goal. I double up on troublesome spots.
The high quality versions like Second Skin's Damplifier Pro will not contain asphalt, which is a cheap filler seen in most or all of the China or Russian made sheets that you see for sale all over Ebay and Amazon. Also, real dampening sheets will be just that, sheets. If it comes on a roll it's likely Chinese junk and full of filler, which is often what smells bad in the cheap stuff.
2- Sound barrier or blocking This is probably the most effective overall material in the process but I think it's the least applied and understood, maybe because it's not cheap and can be more complicated to apply. This stuff is basically a dense "mass loaded barrier" sheet that is "decoupled" from its surroundings by a layer of foam. Dynamat makes some under the name DynaPad. Cascade Audio also makes a series with names like VB-4, VB-3, and Second Skin makes the best in my opinion called Luxury Liner Pro. They all work the same and literally block sound waves. They do this by suspending a heavy, dense layer of rubber (or lead) with foam which is designed to lay on the floor with no need for glues, etc. It works really well when carpet or floormat material is glued to the top of it. It usually weighs 1lb per sq. foot so the weight additions can add up fast. Cascade makes one called VB-4.5 which I used in part of my Gwagen. It is a hard to find .5lb and is very flexible. Their lead-lined stuff is great but its very expensive and most useful for very irregular floorboards with bad sound problems.
VB-4 Barrier.jpg (26.27 KiB) Viewed 63457 times
Gwagen 300GD sound control small.jpg (84.77 KiB) Viewed 63457 times
Above is a 300GD Gwagen getting a full floor treatment of VB-4.5 and DynaPad. The shifter area was covered as much as possible to reduce sound from getting past the control openings. The materials on the floor should always overlap so no air gaps are possible.
The key is total coverage and an "air-tight" approach. It should cover every bit of flooring you have, including under the seats and should not have gaps or holes except where 100% necessary.
Another older but fairly effective material I use sometimes is Thermo-Tec. It's about 3/8" thick and is a mat made with syn. fibers with an aluminized outer layer. I use this as a backing for carpet and works great when you lay this over a high-end material like Dynapad/Liner Pro or just on top of the dampener making a poor-man's barrier product. It's also a great heat barrier and costs very little compared to the other stuff. I do not think it's very effective alone however.
Gwagen 300GD carpet VB-4.5 small.jpg (109.59 KiB) Viewed 63457 times
Above is a Pinzgauer's floor after being covered with a product similar to the VB.
3- Sound absorbing. This is rare to find done correctly in auto builds. It's used extensively on planes and bullet trains and should be part of any 4x4 build I think. The most effective material for this is 3/4" to 1" Melamine foam which can absorb 4K Hz and above. If you can find it, Hydrophobic Melamine is the best since it won't absorb water. This is ideal for cavities in walls and behind trim, etc.. Unlike any other material, it will actually help to absorb the mid/higher sound waves around it.
I'm currently working with something new-to-me called 3M Thinsulate SM600L. This might be my new favorite bulk sound absorber for open cavities and hard to reach pockets, behind door panels, etc. It's designed to avoid water retention and block the mid and higher frequencies. In testing it seems to work very well so far. You can really take care of a lot of dead space easily with this stuff! It will also add some general heat or cold insulation.
https://www.3m.com/3M/en_US/company-us/ ... 035&rt=rud
In the sound absorbing category you also have carpet or any porous outer trim, like headliner fabric. This is very important!! These materials are the final straw for annoying noise. They very effectively keep sound waves from bouncing all over the place. Your ceiling is a major factor in how much noise gets to your ears. Ever notice how quiet a soft top is with the top off (other than the wind and outside sounds)? All that engine/gear/road noise we are trying to control just beams up into the air when there's no top to reflect it.
Volvo C303 carpet.JPG (101.54 KiB) Viewed 63457 times
Above is a Volvo C303 that just had a custom headliner panel made. Under it is Rattle Trap to keep the roof from vibrating, in the middle is a sound absorbing and waterproof foam (in this case, Dynamat's HoodLiner foam) and an auto-grade carpet was applied over the panels for a night and day difference in the noise levels.
Above is the 710K's rear ceiling finished.
Above is the 710K's finished front cab. The floor bottom was left alone in this case but the area behind your leg was treated with Rattle trap and covered with carpet. A small patch was added beside the transfer shifter. I preferred the shop make that a little more finished looking but the budget was very tight.
So these are the basics. You need to reduce your lows, mids and highs by dampening, reflecting/blocking and absorbing, and you want to do this without sealing up your floor where rust WILL hide out.
The Pinzgauer, especially the M models with their soft tops, have unique issues.
The ceiling really needs something to absorb the sound. Aftermarket tops are the best but an expensive solution. Some people have made their own, soft under-layer. Anything you can do will help massively in keeping those mostly high-frequency sound waves from bouncing back at you.
The floor in the back: A sound blocking material goes here. I used the 1/2" Barrier matting material from http://www.heco.net/noise.html with great results before. The key is also to cover the sides as well, and keep that air-tight coverage thinking in mind.
The major treatment areas up front are under your seats, the engine cover and the doors. I lined an engine cover on the inside and then had an upholstery shop cover the outside with great results.
You can also block a lot of noise by making a barrier to block the bed area from the cab. The stock flap is thin and doesn't do much. You can modify that or make your own. Again, keeping that air-tight approach in mind.
And if you haven't already and for the sake of noise and safety, GET RID OF THOSE MILITARY BIAS PLY TIRES.
This post is also in the Tech Sessions but I thought it should have a copy here.
NEWFISHER
Re: Sound Control: General theory and Pinz specific issues.
Post by NEWFISHER »
Thanks for posting this. Im in the middle of " what to do to the new Pinz to make it quieter" stage and your experience is very helpfull. Any links to the trusted suppliers of the products you use?
carbon60
Post by carbon60 »
I would like to say thank you for posting such an in-depth discussion of these techniques! Very helpful.
A.
Brickren
Post by Brickren »
I just bought tires from Treadwright. What a difference. I had Biasd tires and never gave any thought about the ride. It is a military truck, right? Man, its like riding on marshmallows. Ride is softer and grip is better. Pulled a Chrysler 300 out of ditch where car was on its side. Road was icy. I bought their tires with glass and walnut shells in the rubber compound. Yanked car out with minimal wheel spin. 300 weighs same as Pinz, I think. Steering harder at slower speeds, like sitting still. Just keep moving. Wonder what added strain on steering gear.
1975 710M
2000 Ural Tourist
Having had several different tire sizes on my Pinzgauers over the years, I can say with certainty that wider tires steer harder (A LOT harder!). You can compensate with higher pressure in the fronts; for example, I run 60psi in the front of my 712W for on road use.
When I bought 8" widened rims for the 712W, they came with 295/75R16s on them. The steering was so hard that I thought something had broken, and I was worried that I couldn't stay on the a winding mountain road - it was that hard to steer. Now I've changed back to 265/75R16s (also from Treadwright) but I also looked at the tread width - for example, their "Claw" has a 9.5" tread width, but their "Warden" tread pattern has only an 8.5" tread width for the same size tire. At the time, they had their "Guard Dog" tread pattern available and that's what I got. Narrower tread makes steering much easier, regardless of the official size rating.
Our 710M got their tire version with the "Kedge Grip" for winter, like you have. While our last few year's winters have not been bad, we have not needed to chain up and my son now has fun driving it around in the snow and pulling out vehicles that are stuck. I got the regular tires on the 712W, as the weight and extra axle helps compensate in the winter.
When these wear out (and they are wearing at least as well or better than virgin tires) I'll get more from Treadwright. We've had them 4 years on the 710M and 3 years on the 712W. Their tires are half the price of new, and work just as well.
itsalljake
Post by itsalljake »
Really great to information Vince, spot on description of sound wave cancellation. Thank you for all the vendor info as well. You repeatedly mention using caution when covering flat (bottom) surfaces to over rust cover, how did you attach the floor panels in the cab, are they affixed or removable?
1972 710M
Are you referring to the floor pics above? That is in a Gwagen and when the seats are bolted back in, it holds down part of it. The area where your feet go is held in place because of the weight of the material, just like the floormats. It is sort of tucked around various irregular floor parts that hold it in too. In the case of a roll-over, part of it might fall but if that ever happens I have other issues to deal with. Being able to take everything out easily is essential for cleaning and drying in case of deep water or big spills.
In the case of the 710K, the rear material was mostly held down by it's own weight. In the front, the area behind your leg was well cleaned, dynamatted and then they used glue for the carpet. The roof was the same thing.
I will add 710K pics that I forgot about above.
Here's a pic of the back floor. The floor liner is the stuff from Heco and it's just laying there. It's dense and fairly heavy, like thick rubber, but it insulates sound, unlike solid rubber. And yes, after doing all of this I really wanted to have the seat brackets painted and seats recovered but that would have been way too expensive for that build.
Jake2015
Post by Jake2015 »
Vince, in the last picture of the 710K rear, is the floor mat the 1/2" Composite Barrier Floormat (07652-Black) or the 1/2" Floormat (07661-36" wide) (or 48" or 60")?
Also, is the carpet covering the sides and top of the wheel wells glued? Is there anything under the carpet?
Thanks for the great information. I need to quiet my 712K. I'm thinking of doing the cab first and as you suggested changing the curtain between the cab and rear area to something better to block the rear sounds coming forward. Then tackle the rear when more funds are available. Any suggestions for the curtain material?
_________________
1977 Austrian 712K
http://www.swpinz.com
Facebook: Southwest Pinzgauer
It was the 1/2" floormat material from Heco (it's high quality stuff). Sorry I don't recall the width. The middle floor area was covered with the composite mat. The issue when buying is there's no way to order exactly what you need given the coverage needs. That's why the middle material where the passengers feet would go have the binding strips. We cut out what was needed and bonded a leftover piece to make it work. It ended up looking kind of nice though, I think. One of those strips is just for looks so it matches.
My thinking on using the floormat stuff for the back/cargo area was the length-wise ribs made sliding equipment in easier than the composite surface would have. In hindsight I may have ordered all floormat material. I guess I was worried about the ribs coming out uneven when I knew we had to cut/fit that middle part of the floor plus the ribs seemed like they'd trap dirt from shoes and might be harder to clean out. The budget kept me from ordering anything over the bare minimum so I couldn't play around at all.
Keeping in mind that the wheel well areas were 100% free of surface rust and fully painted, yes that area was glued in spots although not heavily; it could be removed without much work. Yes there was some Rattle Trap applied underneath but only on the vertical section where rust would be very unlikely to start. I think the pieces were about 7" by 12" and may have been doubled up since that is a fairly "tinny" area. You definitely don't need full coverage on any panel to stop vibration. I probably covered about 60% of it overall.
If I had the budget, I would have ordered the floormat barrier or VB liner to put under the carpet, and glued the carpet to it instead. The weight and seat/seat-belts, etc. would pretty much keep it down. You could just do a few spot glues then or velcro tabs, or even another mechanical bond of some kind. I had the idea that for next time, I'd embed rare-earth magnets into the edges/corners. I had some window curtains made like that for camping, with the magnets sewn-in, and it works great.
The cab curtain would be nice if you made it from the sound blankets made for industrial shops to isolate loud tools/machines and service areas, which is a quilted fiberglass-based material. It would block and absorb unlike the stock curtain. An upholstery shop could cut put a window in the middle. Sewing magnets into the bottom might be a good way to seal it up quick, or velcro it. Enoise has them http://www.enoisecontrol.com/products/sound-curtains/
I've done 4 sound jobs on "K's" over the years and never seem to have the budget to really do it right. The upholstery shop, plus my time and materials all can add up quick so I understand but I think sound control is as important as seat belts, brakes, etc.. I'd love to really give it a try just once with the budget needed and do some sound measurements before and after to prove the benefits once and for all. I can dream. :?
I just edited my old post with a couple updates. I recently "saw the light" when handling some new (or new to me) materials from 3M and Second Skin.
I take back some of my original thoughts on brands and will now only be using Second Skin dampening sheets. The quality is just so far above the usual that I see no reason to waste time on anything else. Also their Luxury Liner Pro is simply the best thing out there when it comes to sound barriers. All their stuff is USA made to boot!
The other and newest encounter was with 3M's Thinsulate Acoustic Insulation (SM600L). This is now my go-to cavity, headliner and door filler. I'm currently installing some on a 4x4 and it's actually fun to work with and easy to find, unlike certain foams made for the same basic purpose. There's also no smell, no itchy fibers when you cut it and its very compressible and flexible like a blanket. It's not cheap but I don't see anything competing with it. It's similar to what we know as "Thinsulate" that's been in our jackets and gloves for a long time but this is made just for the purpose of automotive sound control! It's also hydrophobic so water isn't sponged up and it comes on healthy sized rolls of 60" wide.
This stuff may be ideal in designing soft top mods for a Pinz. I could see it being applied underneath or sandwiched between the outer layer and a quilted, inner finish liner.
Oh and unfortunately Heco isn't selling sound control products anymore! This is a big loss but luckily alternatives exist.
I'll try to post some pics later.
Jake2015
Post by Jake2015 »
Vince,
Thanks for your update as I have been looking to finally make some purchases. I had noticed Heco wasn’t selling the mats anymore. What would be the best alternative? I’m specially looking at the floor near the rear doors in my 712K, not just for sound but also for a great deal of heat coming up. Things I’ve found may not stand up to the foot traffic at that location.
_________________
1977 Austrian 712K
I don't know how far you want to take it and what your budget is but I'd found out if you can reflect that heat first. You could mount a piece of aluminum spaced off the underside slightly over the exhaust pipe to take care of most of the heat. You could also try DEI's "Form-A-Barrier" underneath if you can't make up a reflector from alum. sheet. https://designengineering.com/formable-hard-shield/
If the heat issue is taken care of, I'd probably use Second Skin's Luxury Liner Pro on the floor, then glue or mechanically fasten an auto carpet and/or floormat material on top of that, like https://smile.amazon.com/gp/product/B008VIP5TE With that on top of the liner barrier, it would further reduce sound waves and provide a nice wear surface that's easy to clean.
If you still have heat issues or don't or can't reflect it underneath first, I'd look into DEI's "Under Carpet Lite", then bond that to a dense floormat like above. That would create a low budget, decoupled sound barrier product itself which can also handle heat. https://designengineering.com/under-car ... nsulation/
No one material will solve this issue that I am aware of. I think reflecting some of the heat underneath would be important first.
rollingpinz
Post by rollingpinz »
I know that the pinzgauer was never meant to be a comfy cruiser and I know that 50 years has only made it worse(body mounts and original dampening pads hardening). But, I’ve been making slight improvements. I replaced the weatherstripping on the door tops so they don’t rattle. I replaced the muffler with a stock recreation. This weekend, I replaced the sound dampening pads with second skin damplifier. I put a few pieces under the driver’s seat. I haven’t put anything in the air tunnel because I’m worried about rust and the material getting sucked into the fan.
All of these things make a difference, but the one thing I can’t figure out is how to reduce the gear noise coming from under the bed. I have a 3/4” thick rubber mat in the bed and it helps, but it is riddled with holes because I’m scared of rust.
I’d like to do something, but don’t want to invite rust or loose functionality because of delicate materials.
Is there something I can put on the bottom/underside of the floor?
Would a sheet of metal suspended between the bed floor and the differential help?
How about second skin sludge(again, worried about rust)?
I'd consider making a large removable floor cover instead of that rubber pad. The rubber is just transmitting sound waves right through it. It's not actually a good insulator for sound, especially without a decoupling material under it.
One of the Gwagens I did started with spraying the floor with rust inhibiting spray then making a floor liner with Second Skin Luxury liner pro covered with marine grade carpet. (like above) That made a huge difference. There's no replacing that layer of ML Vinyl.
To be effective for the Pinz cargo floor it should cover the entire area back there. It would be pricey to use that much material but not much else would work that well. You could take it out or lift up each half once a year or whatever and check for any signs of corrosion starting. The CRC or Blaster rust sprays should stop any of that though.
I'm about to start a major attempt by fully insulating a Unimog cab. I have some great materials from Second Skin including their newer gen "Mega Zorbe" plus I'm lining the engine area with some of DEI's heat liner foam.
