I'd like to find or replicate the original accessories that would be clamped on the front of a 710K. Some folks just put PVC tubes there, but I want to match the original parts as best as possible, presuming they don't exist.
Can anyone help with pics, dimensions, links, etc?
I see these https://swissarmyvehicles.com/pinzgauer ... ic-6-meter also, but it seems unlikely to me (maybe I'm wrong) that a truck would have two of these clamped in up front. Thoughts?
710K front antenna tubes (find or replicate)
Re: 710K front antenna tubes (find or replicate)
I found this in my files, hope it helps.
-RP
-RP
- 174222489_3904014179695232_5478174364566522233_n.jpg (127.83 KiB) Viewed 382 times
They are not "tubes". They are a telescoping crank up mast. Not very tall, 6meters and I believe they were made by Geroh. SAV has one in stock.
75 Swiss 710K
W9YG
W9YG
Oops! sorry. I see you had already posted the link to SAV.
75 Swiss 710K
W9YG
W9YG
I now have one of the antenna masts from SAV. They're pretty sweet, actually.
Model is Geroh 5985, 6m
Manual attached.
19ft4in from bottom to top when fully extended. Takes a 1.0in mast of up to just under 4ft into the top section, so in the end it'd be about 23ft tall if you kept the whole thing collapsible.
Manual attached.
710K
What antenna are you putting on it?
75 Swiss 710K
W9YG
W9YG
