Tool box curiosity
Posted: Fri Oct 16, 2015 11:13 pm
I was cleaning out the tool box on the side of the pinz today to remove dirt and debris. Noticed that there are holes in the bottom to drain the box, yet there is a rubber gasket around the door to box seal to keep out dirt and debris. The logic escapes me as to the gasket and the holes both.
Any enlightenment to be offered?
Re: Tool box curiosity
Posted: Sat Oct 17, 2015 8:48 am
by 4x4Pinz
always thought of it like a dive bell. You should also have a deflector piece of metal that does not allow splashing to get up too far into the box. Works well as I know mine has been under water and the contents in the box did not get soaked.
Posted: Sat Oct 17, 2015 10:45 am
Actually, that piece of metal is intended to be used as a base for the jack when in soft soil conditions like sand. It does serve as a sort of splash guard.
I do like the idea of a diving bell as the thing has been in water and mud...quite unintentional. It just was part of the off road trail I went on with some friends. None of us had been on that trail and did not know what we were going to find.
I thought it time to clean out the mud and noticed there were holes to drain the water. All my tools and other important items are in ammo boxes, water tight and safe.
Thanks for your response.
