Cage and roof rack design input requested
Posted: Sun Jan 22, 2017 12:06 pm
Good morning,
I wanted to get your input on the cage design that we have come up with for my Search and Rescue Pinzgauer.
The goals for the build are:
1. Provide a mounting point for all of the lighting and antenna’s needed for Search & Rescue use. Rack needs to be able to have cabling ran inside, both power & ground for lighting and coax for antennas.
2. Keep overall weight as low on the vehicle as possible (example, using aluminum for roof rack platform, thinner walled tubing where feasible (without impacting structural integrity), flexible attach points as low as possible for adding fuel/water jugs, etc.)
3. Provide a platform to hold SAR gear (both fixed gear that belongs in the rig as well as gear used on a specific mission, which includes litters, packs, ropes, etc.). Mission gear is put up and down several times during a mission so attach points and straps should be fast to deploy and easy to operate.
Enable flexible attach points to adapt to different equipment used at different times of the year (i.e. Maxtrax in the winter, ropes on rigging missions, fuel for long missions or overnight, etc.) as well as for other uses beyond SAR, including off-road expedition and camping.
4. Support future upgrades including an awning and future adaptable storage as new use cases are discovered.
We are planning to replace the wood rub rails with tubing and build up from there. For the front we will not be connecting into the front bumper as it's connected to the drive train and needs to be able to "float" independently from the rest of the body. We are planning to build plates off of the front windshield hinges and attach there. The roof rack will only cover the area behind the cab. Weight will be centered on the two ladder racks going down as the front and back of that section, so it should have plenty of support. The front section will only be carrying the weight of the rack itself as well as the front lighting. We are also going to be looking to see if we can add additional structural supporting behind the rack attach points to add more support in the event of a roll-over. But we haven't sorted that out yet either..
As always, I would appreciate any and all feedback and criticism from those with experience. It has always been very helpful to my build.
Ben
Ben
