Do door hinge pins from side doors match front door hinges?
Posted: Tue Nov 14, 2017 7:38 am
by Jake2015
I have a stuck hinge pin in one of my front doors that has resisted all attempts to remove it. I’m about ready to remove via destructive methods, but wanting to have a replacement pin. I haven’t found hinge pins on SAV for the front doors, only the K side doors (part number 7131760151). Does anyone know if this would be the same pin as used in the front door?
Re: Do door hinge pins from side doors match front door hing
Posted: Tue Nov 14, 2017 9:32 am
by Hotzenplotz
Jake
The pins are different
front door pin 7111760461 diameter 8mm length 61,5mm
side door pin 7131760151 diameter 6mm length 45mm
you can find all parts on
www.puch.at, the manufacturer's site
Posted: Tue Nov 14, 2017 12:24 pm
by whitesik
I have found that lots of PB blaster and an air powered impact hammer with pointed bit to be quite effective and actually preserves the pin. However, while out, I would replace them. They are readily available.
Posted: Tue Nov 14, 2017 2:03 pm
by Jake2015
Hotzenplotz, thanks for the information.
Whitesik, I have tried that, but perhaps I need to try again.
