Rear "K" door into a 712M
Posted: Sun May 06, 2018 8:21 am
by Pinz aus
Hey guys
I have been lurking behind the scenes but doing plenty of reading (and learning) since my last post.
Also since my last post I have become a Pinz owner, a 712M with a hard back canopy fitted.
It's going to tidy up quite nicely I think and I'll put up some more info and my plans sometime soon but I'm after some help and advice at the moment.
I want to fit a rear passenger door to the left side and want it to blend into the vehicle as much as possible.
So:
Has anyone on here fitted rear side doors into an "M"?
Has anyone got dimensions to cut in a door as per factory K spec?
Any photos of a rear left door, footwell, hinge mounts and frame would be greatly appreciated.
Also any other information tips and advice
Re: Rear "K" door into a 712M
Posted: Sun May 06, 2018 8:25 am
by Pinz aus
- Here it is
- IMG_6351.JPG (1.56 MiB) Viewed 5169 times
Posted: Sun May 06, 2018 1:00 pm
by EmbarkChief
I can’t answer any of your questions but that is an interesting looking Pinz you have there!
Posted: Sun May 06, 2018 2:13 pm
by David Dunn
Definitely not for the faint of heart, as the pan needs re-enforcement for the door cutouts.
There was a 712 for sale in Hawaii a couple years back converted from a M to K, but didn't look as any consideration was given to stiffening the pan for off road twisting
Prof Pinz's conversion of his 718M is here:
viewtopic.php?f=8&t=8355
The pan behind the cab is almost identical between a 712 and 718
From your pic it appears you have an Austrian spec'd 712M, depending on it's built, you may have an enlarged fuel tank that will need to be replaced. A gas tank and door don't occupy the same space too well.
Posted: Sun May 06, 2018 7:20 pm
Sorry to go off your topic but your truck is very unique.
Hard sides but soft roof, what’s the box above the rub rails?
Even your door handles are modified!
Posted: Sun May 06, 2018 9:00 pm
David the fuel tank should not be an issue as "Pinz aus" indicated he wants the door on the left side.
Posted: Sun May 06, 2018 10:36 pm
by David Dunn
edzz wrote: ↑Sun May 06, 2018 9:00 pm
Yea, I skipped over that line, but below he did mention rear side door
s. And his post was getting close on my three finger rule.
Posted: Mon May 07, 2018 6:54 am
by Pinz aus
Thanks for your comments guys.
I do now remember reading through Prof Pinz's posts ( thanks D.D ) back when I was searching 718's in Aus, what he has done but to a lesser extent and on one side is what I want to achieve!
Because I have the hard sides and I want to fit a hard roof I want something that is in keeping with its look, that doesn't mean it has to be 100% correct as the rest of the top won't be anyway, but as far as the lower body goes I would like to form it like a "K".
TechMOGogy the box above the rub rail is a tank, there is one on each side and they are made of stainless. They were fitted by a previous owner.
Apparently he had intentions of shipping it to South Africa and was going to carry oil (I am guessing for the vehicle) in them but none of that ended up happening.
I am going to put of a build thread and then I can tell a bit more about the vehicle and what I'm up too!
Posted: Tue Sep 18, 2018 9:26 am
by dionpinz
How did you go with your rear door Pinz Aus. Funny thing is I am thinking of the same thing but on both sides. I have since 2004 been restoring one of the original australian pinnys like yours. Now my boys are growing so rear doors would help seat them. I remember your pinz being in tasmania and if you are still there then it might be worth hooking up with another pinz owner over there. He has a yellow 712M pinz from the UK and has cut a door in the back only on the left side. Look on youtube for his channel Blakey010.
There is also info on Robis pinzgauer forum. Good photos on
https://pinzforum.kiruna.de/viewtopic.php?f=26&t=5834.
Lucky my pinny is still in restoration so cutting what I have made is easier. PM me if you would like to talk further. Dion.
Sent from my SM-T800 using Tapatalk
