Hi All
I have replaced all of my sound deadening (with Megasorber) In doing so I took the horn off. Now I have finished the job I couldn’t remember exactly how it went back but I have bolted the 3 springy strips to the back of the horn and at the bottom to the angle bracket. Trouble is the horn tilts forward a lot. I can see no obvious way to mount it differently and I really don’t want to start bending stuff.
Got any ideas? Even a picture would be great.
Sam
Horn Mounting
- GenevaPinz
Re: Horn Mounting
I mounted mine in place of the convoy light, so it faces directly the hole in the front grille. I had to build (big word for the work involved) a small "adapter" from a small flat piece of steel to get the correct height. No need to touch the electric wiring as it is just next to the original emplacement.
Hope it helps...
Hope it helps...
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
