Closed cell foam for 712 m
Pols497
Post by Pols497 » Wed Jan 02, 2019 5:21 am
Has anybody got any recommendations for foam in the rear of the top of my 712m and where can I purchase it. Too much to sort through on Amazon or Ebay. Help will be much appreciated.
Roger Melton
Re: Closed cell foam for 712 m
Post by rmel » Wed Jan 02, 2019 9:47 am
Hard to give a completely intelligent recommendation without a wee bit more info
on the application and what your trying to solve/improve.
But, I have had good experience with Second Skin Audio's products, made in U.S.A.
Primarily engineered for Sound Deadening and Vibration dampers, but they do have
closed cell water proof materials, and it drops the noise figure considerably, not sure
that matters in your case. In general your likely better off buying from a company
that focuses on Mobile and Marine applications than some random materials off of
eBay or Amazon -- IMHO.
https://store.secondskinaudio.com/close ... n-the-usa/
Rescue Pinz: 73' 712M
Pols497
Post by Pols497 » Wed Jan 02, 2019 10:59 am
Thanks Rmel I guess I should of thought it through a little better. I'm wanting to insulate from the heat in summer and the cold here in Oklahoma. I have a eberspacher but it can't keep up with the curtain rolled up.
Roger Melton
Post by rmel » Wed Jan 02, 2019 12:05 pm
I suspect you are well aware of the Pinzgauer insulated tops and cab separator from TuffRiverStuff dot COM.
Also hearing on this forum there's a rather deep backlog unfortunately.
cheers
Pols497
Post by Pols497 » Wed Jan 02, 2019 5:35 pm
Yes I've been on the forums for 10 years. I don't want to spend that much for insulation. I've seen somewhere on the forum somebody had some foam in the roof of their 710 for a little extra warmth
Roger Melton
Post by 4x4Pinz » Wed Jan 02, 2019 5:45 pm
I have had really good luck just using the surplus military wool blankets. They do a good job with insulating and when needed can be used or more specific applications. I currently have one in my Swiss G to help with the summer heat and help keep the flapping down when at highway speeds. Works well and is fairly inexpensive.
Post by audiocontr » Tue Jan 22, 2019 9:13 am
But stinky =)
(2) 1968 Haflingers 1 For Sale
1978 GMC Palm Beach
2001 F250 Diesel and trailer
