Rubber shock cord
Banshee35
Rubber shock cord
Post by Banshee35 » Sun Jul 28, 2019 10:24 pm
So in trying to put my top back down the other day I broke my very dry rotted shock cord.
I see that SAV has replacement sold by the foot. How many feet would I need to do a complete replacement and is there a better option?
I was looking at black bungee cord but not sure which would hold up better or what kind of life I should expect to get from just replacing with the original rubber one?
Garage:
1969 M151
2016 Alfa Romeo 4C
Re: Rubber shock cord
Post by 4x4Pinz » Tue Jul 30, 2019 5:48 pm
rubber shock cord is the best option. many have tried other items with no better results. I saw a truck rope used but the top took one heck of a beating as the rope did not flex so the top had to do all the work, which it did not do very well. Just remove all the cordage and measure for length. Suggest you do all at one time. When I ran soft tops I just bought an entire roll and sold what other owners needed. Found a local source but the price was not much better then SAV. If you do go elsewhere make sure it is UV rated. Some bought rubber cord that was not and here in the desert it barely lasted a year.
Banshee35
Post by Banshee35 » Mon Aug 05, 2019 11:35 am
Well that’s part of the problem is that I would like to have it on hand when I get tearing into it as it won’t fit in my garage.
I just figured somebody must have done in in the past and knew how many feet I needed to order.
Garage:
1969 M151
2016 Alfa Romeo 4C
