Loose ignition key
Posted: Sun May 08, 2022 12:25 am
by MTPinz
I'm curious if I'm the only one with this issue.
When I am on rocky trails/logging roads and hit a large bump, it seems my key tends to jump ship landing on the floor somewhere. Usually I can find it right away but I can see this being an issue if I need to shut the engine off quickly and it finds it's way under the floor tread out of reach.
What causes this? The aftermarket key? A loose tumbler?
Maybe I just need to tether it to the dash. It's not like anyone around my parts will know how to drive a Pinz anyhow, ha!
Re: Loose ignition key
Posted: Sun May 15, 2022 10:46 am
by Daly944
Same issue for me with factory key. The aftermarket key expedition imports sells seems to stay for me though maybe it's just a bit thicker and holds in place.
Posted: Thu Jul 28, 2022 8:47 pm
by 4x4Pinz
There is no tumbler in the pinz ignition switch. All the detent does is retain the key. A couple of scenarios, one you are not installing the key in all the way. The switch is worn out. The key is worn out. Some folks have way too many keys or items on the key chain for the detent to hold.
Posted: Wed Feb 01, 2023 10:04 pm
by AdamKareem87
Same issue key flies out. If anyone has the 2 position Swiss key ignition switch that holds the key well please PM me. :-)
Adam
Posted: Fri May 26, 2023 8:06 pm
by 4x4Pinz
Would love to see how far you are installing the key in the switch. So many owners don't push them on fast enough.
