Restoration & upgrade ideas
SNP
Post by SNP »
I have a 712M which I'm in the process of restoring and then adding a few creature comforts to. I'd appreciate any ideas on what works (or doesn't).
Thanks in advance!
Sent from my SM-G981B using Tapatalk
Hotzenplotz
Austria
Re: Restoration & upgrade ideas
Post by Hotzenplotz »
well, a quick review of the mods I've done:
  • power steering
  • tubeless tires on Ford rims
  • LED headlights
  • seats from a Smart minicar
  • Pertronics ignition and civilian wires / spark plugs/ distributor cap
  • machined off 2 mm from cylinder heads to increase compression when running with 95 octane fuel
  • swapped the hi/lo gearbox for a 710 model
that should keep you busy :D
Albert
Mr Zero
Post by Mr Zero »
The bigger "comfort" items that I would recommend...
  • Power steering (EZ)
  • EFI (Goatwerks)
  • 2.7L motor rebuild (Goatwerks)
  • SAV Power brake booster
  • Webasto or clone heater (depending on your use case)
I would say that the seat swap is more of a preference than an upgrade. Do try before you buy.
Jason @battlebornpinzgauer
[1975 Pinzgauer 710K 2.7L EFI, 1972 700AP Haflinger Pathfinder]
