HUF key blank number?
Does anyone know what number HUF key blank I need for my door keys? I've only got one and would like spares but my local locksmiths can't find a match
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
cronapress
Robin:
I transferred my door locks from my civvi 710M after its terminal dong. They are the Steyr locks. "Should" be the same as yours. I just trundled down to my nearest Timpsons (Kilmarnock) and they had the blanks on the hook. Maybe I was just lucky. Give your branch a try if you haven't already.
Mike 712M
Mike 712M
Thanks, Mike, no Timpsons in my home town. I'll try the one in Burgess Hill as I'm working there this week. Is your a symmetrical bladed key? The closest match I've found it the FOT3 blank (from http://www.keytrader.co.uk/Vehicle-Keys ... Blank.html)
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
cronapress
Result! A response from keytrader.co.uk:
I've deleted the key number for security reasons but it's stamped onto my one key
Hi Robin
You can order the keyblank only or you can order a cut key from us by following the link below. The keyblank is actually FOT3R for the Steyr Puch Pinzgauer series.
Should you decide that you would like us to cut the key for you then please put your key number xxxx in the blue key code box you will find once you have entered the page from the link below.
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
