Back door rattle
Pols497
Back door rattle
Post by Pols497 »
My back door on my 712 M has a rattle when I run it down bumpy roads. It looks like the hinges have some wear on them. Has anyone come up with a fix on this other than replacing the hinges?
Roger Melton
I replaced all the weatherstripping and that snugged it up somewhat. 3M makes one for automotive trunks, etc. that works well and is less expensive than the original.
Pols497
back door rattle
Post by Pols497 »
Does it look like the original rubber trim? Where did you get it? Thanks for the reply.
Roger Melton
No, it doesn't look like the original - it's a hollow round style. I think this was it:
http://www3.3m.com/catalog/us/en001/hom ... utput_html
It also comes in a different size, I think part #08651, 11/16" x 1/2". If I can find my old package I'll see what size I used.
It does not provide quite as good a seal as the original, although I suppose this will vary from Pinz to Pinz. I seem to remember it was less than a third of the original which runs about $40/meter.
I got it at the local Farm & Fleet but I think any auto supply should be able to get it.
Pols497
DOOR RATTLE
Post by Pols497 »
that looks like it would work better than the original, thanks, I'll see if my local NAPA store can get it for me.
Roger Melton
08650 is the part number of the one I used.
NAPA carries it:
http://www.napaonline.com/Search/Result ... &Nty=1&N=0
Pols497
back door rattle
Post by Pols497 »
thanks pcolette
Roger Melton
michaelh712
quick cheap fix
Post by michaelh712 »
My back door rattled a little, even after replacing the rear door weatherstripping.
Another quick and cheap fix:
Slip a rubber hose washer on the male catch on the door and the rattle disappears. Cheapest fix on a Pinze!
Michaelh712
michaelh@updc.org
Educational Anarchist
michaelh712,
Thanks! I'm going to do that tomorrow.
Re: quick cheap fix
michaelh712 wrote:My back door rattled a little, even after replacing the rear door weatherstripping.
This works well if your latch mechanism is loose enough (too loose?), however if you are unable to open the door after the addition of the hose washer, have someone else repeatedly shove on the door (from the outside) while you work the release handle after a shove or two it should release. Your door latch may not be loose enough to need a full hose washer. Don’t ask how I know about this… :roll:
Ed
chacaocop1
Post by chacaocop1 »
I had the same issue. The hose washer should work. I solved my problem like that.
CHACAOCOP
1973 712M
