Hey Guys.
I finally got to go through the truck more thoroughly today, and found a few things I need to do and get. The bench seats appear to have a little pin on the back rests that is intended to snap into a receiver of some kind on the rear rail. Mine does not have the receiver. I also had to remove the antenna mount to get the truck into my garage...(would you believe I forgot!!), and found the square gasket needs replacing. I was hoping to get them all from the same place, just to save on shipping, but I don't know what to look for...
Could someone point me to the parts I need?
A few body related items...
Re: A few body related items...
Hold on to your wallet ... here's the square gasket: http://www.pinzgauer.com/showdetails.ph ... 111950331/
I used 2 layers of scrap epdm rubber roofing and it worked out fine for 5 years so far. I used the antenna base as a pattern and a 9mm shell casing to cut out the 4 holes.
The rear seat backs snap into a rubber insert: http://www.pinzgauer.com/showdetails.ph ... 111790971/ that is mounted in a casing: http://www.pinzgauer.com/showdetails.ph ... 111790991/ . Hopefully the casings are there so you just need new inserts. I've found that putting some petroleum jelly in the insert adds to their life. If you do need the casings you'll also need the metal plates: http://www.pinzgauer.com/showdetails.ph ... 111790861/ they fasten to and the appropriate screws.
Although I've referenced SAV's site I'm sure Scott at EI has them also. You might be able to find some used casings if yours are missing.
Hope this helps.
Hope this helps.
I had some but cannot find them right now.
edit: they were in the box of stuff I donated to the auction at NWMF last year.
Thanks! This isn't urgent, but things to add to the list of stuff I want to get.
Cheers!
Cheers!
I used 1/8" thick or so cork-rubber gasket material from a local auto parts store for replacing my antenna gasket and a few feet of it was only about $12; it works great.
Chris.
https://www.supanik.com/pinz
Ya, I had some laying around too, and used it for the metal cover I made out of old aluminum siding. When I re-add the antenna mount, I will pick up a new gasket.CentAr712 wrote:I used 1/8" thick or so cork-rubber gasket material from a local auto parts store for replacing my antenna gasket and a few feet of it was only about $12; it works great.
Berger,
I have some good used seat parts for sale that you need.
PM me with which parts you need and how many.
It looks like new the 3 parts you may need add up to 25.00!
Michael
Michael
Hey Michael...PM sent!michaelh712 wrote:Berger,
Michael
