Glove box light switch?
After doing some electrical repair last weekend I have realized that my Pinz has a light next to the gove box. That's great, however for the life of me I can't seem to locate the switch to turn it off! I've been using the battery disconnect Where is the on off switch?
-1972 710M
Re: Glove box light switch?
Flip the cover of the light itself, it sort of rolls up, and turns on the light.
- Jack Russell Racing
^ IIRK, as the metal lid rolls upward, it makes contact with the dashboard housing and thus closes the circuit.
Thanks! I had noticed the "door" but didn't try and close it all the way . I'll get that sorted out when I get home.
-1972 710M
It is actually called a map light. For the co-driver to read the map.
I eventually taped over the map light cover/switch to prevent it from ever turning on. You won't notice that it's on unless it's dark and I never run my trucks at night. Usually.
Would it not be easier to just take the bulb out?
