Cab Seat Cushion Replacement
landy
Post by landy »
My original cab seat cushions are a little worse for the wear. Any suggestions for direct replacement, all-weather cushions, or possibly reupholster the original cushions with more padding and different material, or other ideas?
Thanks!
Re: Cab Seat Cushion Replacement
The original cushions in mine were replaced with newer foam type. They have a wood bottom and sit a bit higher as they do not have a depression in the centre of the cushion.. Check with SAV or EI for replacement pieces.
I have since sold the seats to another forum member that wanted stock seats.
edit: Keep in mind that you are going to spend some $$$ for new cushions. Might be less expensive to have them recovered and new foam installed.
krick3tt wrote: SNIP
It will be MUCH cheaper to buy new foam and vinyl and then have them re-upholstered.
Many shops can do it all but I found a foam place close to me where they custom cut foam in the density I wanted (they had samples of marine foam to try out various firmness)
Purchase marine grade vinyl (thicker and stands up to UV rays) and just supply everything to the re-upholsterer
Good luck with the project
ps - if you need to cut/shape the foam use an electric carving knife (<$10 at WalMart)
