View unanswered posts | View active topics It is currently Tue May 23, 2017 8:35 am
Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
 Overdrive (again)
Author Message
Post Re: Overdrive (again)
Quote:
I can't help but wonder if the Pinzgauer engine would have enough power to drive the vehicle with such a reduction in gearing?
I put the TD overdrive tranny in my 712W (which also has Jim L.'s 2.7l "torquer" conversion). I get exactly 60mph at 3000 rpm in 5th (overdrive) and while that just barely works with the additional power, the Laycock ratio seems slightly better (7% lower ratio) which I would prefer. Plus, with the OD you don't lose the low ratio of first gear (the TD tranny trades first for the overdrive 5th). If proven reliable, I'd say it is definitely a better solution.
Keep me in mind if you decide to put a kit together! Nice work!
_________________
Mon Apr 06, 2015 5:18 pm
Profile
It has been working flawlessly. Still, when I hit that red button and the truck calms down and almost shoots forward while entering the freeway, I have to grin. I guess it hits the right torque band when the RPMs drop back down, because I swear it feels like a turbo boost.
Mon Apr 06, 2015 5:45 pm
Profile WWW
This sure is nice. A way better solution than a TD tranie.
The key here is your pick of the shaft with constant velocity joints.
Would be near impossible to eliminate vibration with u-joints.
Impressive bit of engineering.
Hmmm, now you got me thinking about my TD tranie.
Wed Apr 08, 2015 3:58 pm
Profile
Good technical write up on the care and feeding of the J Type OD unit.
http://buckeyetriumphs.org/technical/jod/JOD1/JOD1.htm
_________________
Puller: 710K 2.7L EFI
Fri Apr 10, 2015 9:43 am
Profile
Bump!
So, how is it working after a few years? I suspect very well as there are hot rods with this overdrive unit and turbo volvos that have a lot more power and torque.
I'm curious about a couple things, had you considered a P type, which is supposed to be a later, slightly more robust version, and has anyone else yet copied your daring exploit?
Keep up the good work!
Sun Mar 19, 2017 2:56 pm
Profile
Beez,
It's been working perfectly. I found out later on that the OD unit by way of serial number, was from a Volvo 740 Turbo. This had 180 HP!
I found another off Ebay only a few K away (serial number) for $175 as a backup.
So..... I'm not too concerned about robustness. I have an oversize sump and have measured the oil temp several times. No problems.
Time will tell, but freeway driving at 60-65mph is soooo nice.
Mon Apr 03, 2017 9:37 pm
Profile WWW
Excellent! That's some beautiful work!
Have you been able to measure any change in mpg with the o.d.?
Chris
Tue Apr 04, 2017 1:33 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
