View unanswered posts | View active topics It is currently Tue Aug 22, 2017 2:22 pm
Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4
 MRAP 24 volt Warn winch
Author Message
Post Re: MRAP 24 volt Warn winch
This is all you need to do when installing a winch up front a pinzgauer.....or you need to swap your front springs to heavy ones .
you can make these in aluminium to if you want...mine are 3.5 cm thick.... about 1.3 inch.
_________________
off-road until i die
Thu May 18, 2017 8:26 am
Profile
That plate where it says MULE .....cut it away..it will only act as a mud collector :mrgreen: .
_________________
Thu May 18, 2017 8:49 am
Profile
Online
How did you make those spacers? I WANT!!!!
_________________
(2) 1968 Haflingers One For Sale
1979 Mini Cooper Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Current Company Cars
2017 MKT
2017 F-150
Thu May 18, 2017 8:52 am
Profile
They are made of ERTALON......this is some kind of heavy Duty plastic but can be made of Alu.
They come between the 2 rings of the lower spring Seat. so you have the frist cup That sits on the vinger
That is sitting on the axel....than comes the rubber ring ,Than your spacer, and finely the cup where the spring
Sits on . 8) THEY COME BETWEEN 4 AND 5 IN THE PICTURE BELOW .
https://www.pinzgauer.com/parts.php?cat ... view=04-15
_________________
Thu May 18, 2017 9:07 am
Profile
Check the toe-in before you mess with spring spacers.
_________________
Thu May 18, 2017 9:56 am
Profile
How do you change the camber by altering the toe-in.....if the wheels are sitting inwards meaning negative camber,
There is notting to adjust there on a pinz :?
_________________
Thu May 18, 2017 10:11 am
Profile
If the toe is outward, driving forward pulls the bottoms of the wheels outwards - this gives the appearance of weak springs. Toe inwards pulls the bottoms of the wheels inward when driving forwards, this flexes the suspension downwards and lifts the body. Even with a proper toe setting you will get a different distance from the bottom of the diff to ground after rolling 10-20 feet forward than doing the same in reverse.
To evaluate the springs, you must have the toe set properly, put the truck on a level hard surface, and with the wheels straight ahead you need to move the truck forwards 10-20 feet to correctly evaluate the ride height.
_________________
Thu May 18, 2017 10:41 am
Profile
You may have a point here but if it helps to bring the front back up after adding +- 50kg , 50cm in front of the front axle....i have my doutbs .
_________________
Thu May 18, 2017 10:47 am
Profile
Another member here gained 1-2" of ride height by setting the toe inwards properly. He thought he needed new springs until he realized that his truck had toe OUT instead of toe IN.
_________________
Thu May 18, 2017 10:58 am
Profile
Who is online
Users browsing this forum: Google Adsense [Bot], Rookie and 3 guests
Search for:
Jump to:
