Smartcar seat airbags
Did anyone ever figure out how to remove the smartcar seat airbags safely or find instructions that don't cost money?
-Erik in Colorado
Re: Smartcar seat airbags
I figured it out. You pop open the lower back of the seat cover, which is connected with a sort of hooked seam you can pry apart. Then you peal up the back until you reveal the 3 nuts holding on the airbag, and the one connecter. Remove the nuts, pull out the connector and then you can pull out the whole airbag unit.
-Erik in Colorado
Thanks for this, I am going to have to try it out. Been riding with these things and never felt good about it...
Did this over the weekend. Was able to remove the airbags and then put the plastic housing back in the seat, so it looks like it did, just no surprises.
Very easy to do
Very easy to do
- rsz_20200906_175835.jpg (102.95 KiB) Viewed 4107 times
- rsz_20200906_175820.jpg (128.96 KiB) Viewed 4107 times
