Webasto Air Top 2000 Install
Mr Zero
Post by Mr Zero »
After doing an inspection and some minor repairs on the original Eberspacher heating unit I decided to err on the side of caution and installed a new 2KW Webasto 12V gasoline Air Top 2000 in its place. I already had a 60A step-down converter installed for the EZ PS, so I pulled from that for the heater (if you don't already have a 12V converter for accessories, then a small inline unit will get the job done inexpensively). The heater is plumbed directly to the main tank, because EFI, but if you're carbureted then a T off of the main fuel line will function as the original Eberspacher setup did. Both the fuel pump harness and the heater control harness have enough length to mount literally anywhere in a Pinz. The 3saurus mount adapts the Webasto (should also fit Espar and Chi heaters) to the original K ducting, which allows the Webasto to function perfectly as a bunk heater in my setup. The pics below should tell the rest of the story. Loving it! :D
Whether you go with an Espar, Webasto or Chinese unit, I highly recommend reviewing and following the install, setup and operation tips in this article.
Mr Zero
Re: Webasto Air Top 2000 Install
Post by Mr Zero »
By the way, if you search eBay for "Webasto Air Top 2000" you should find a number of Russian sellers selling in the $600-$700 range with a "Best Offer" option. A $500-$550 offer should get you one of these heaters. It did for me. If you can find one, a 24V petrol Chinese heater is going to cost you the same.
The Webastos out of Russia seem to be new surplus as they ship without manuals, installation instructions, etc. However, I had great communication with the seller and got a sweet deal.
whitesik
Post by whitesik »
That looks great! Can you post more about where and how you mounted the controller?
75 Swiss 710K
W9YG
Mr Zero
Post by Mr Zero »
My hardtop is new fabrication by Andre at Fat Fabrications due to some "unpleasantness"... Anyway, the new top has additional framing and reinforcements. The top has paneling in the interior upper corners that runs the length of each side in order to conceal electrical, etc. I mounted the heater controller on this panel in the rear section of the vehicle so it could be easily accessed from our sleeping area. Specifically, I ran the harness from the heater, under the lip of the cab wall using the wire retention clips (as did the original heater electrical), to the passenger side, up the wall and behind the aforementioned paneling.
The harness provided with the heater is long enough to fit the controller literally anywhere inside the truck.
whitesik
Post by whitesik »
I am resurrecting an old thread here to see how the Webasto heater is doing. Yes, life and procrastination has bitten me as the price on these have skyrocketed but i may still get one. I have read about some problems with sooting in the petrol model that have caused malfunction and/or high maintenance. Any issues after a year? Still recommend? Thanks!
75 Swiss 710K
W9YG
Mr Zero
Post by Mr Zero »
whitesik wrote: Sun Nov 20, 2022 10:38 am I am resurrecting an old thread here to see how the Webasto heater is doing. Yes, life and procrastination has bitten me as the price on these have skyrocketed but i may still get one. I have read about some problems with sooting in the petrol model that have caused malfunction and/or high maintenance. Any issues after a year? Still recommend? Thanks!
The Webasto is still rock'n it! The only mod I've made is to add a valved Y-duct (pictured below) for the option to regulate between bunk and cabin heat. I highly recommend reading and following the guidance in this article and you shouldn't have any maintenance issues. TLDR, run the unit at max output to heat the interior to desired temp then discontinue use. Running at max significantly mitigates carbon build-up. The only other observation that I have to offer is that ambient temps above the built-in safety no-start (84F?) can prevent the prescribed monthly maintenance run of the unit (15min on max output), so this will result in a few false starts when you do finally run the unit due to fuel having drained from the line. In this situation the 2nd or 3rd start will fire it up and then every time after that within a few of weeks of priming the pump/line. I still highly recommend this unit.
whitesik
Post by whitesik »
Thanks Jason. My thoughts exactly on the valve for up front vs. rear. Sounds like it also needs a bulb primer in the line for those times it sits too long.
I don't see the pic.
75 Swiss 710K
W9YG
Mr Zero
Post by Mr Zero »
whitesik wrote: Thu Dec 01, 2022 7:22 pm I don't see the pic.
It should be displaying properly now.
