Smart Car Seats
totaljoint
Re: Smart Car Seats
Post by totaljoint » Sat Oct 06, 2018 12:49 am
They worked great in the rear of my G:
Andre
Re: Smart Car Seats
Post by Andre » Wed Oct 10, 2018 10:47 am
I’ll be in So Cal this weekend. I can help get the seats mounted for anyone wanting to do so.
(903) 717-4018 shop
(951) 765-7224 cell
74 710m and (1) pinz trailer
Re: Smart Car Seats
Post by pcolette » Wed Oct 10, 2018 11:01 am
totaljoint, Are those the Scheel-Mann seats you have in the front? And if they are, what do you think of them? I've been very tempted to add them to mine but the price has so far kept me from doing it.
2002 MB G500 (For Sale)
totaljoint
Re: Smart Car Seats
Post by totaljoint » Wed Oct 24, 2018 2:46 pm
Yes, those are the Scheel Mann seats.
Love 'em. I can't compare them to other- more affordable brands as they are the only ones I've tried, but they were very comfortable for the drive from San Francisco to Port Townsend. Seem to be very durable fabric too. I especially like that they don't have high bolsters on the seat sides. So much easier to slide in and out in the raised truck.
Ed
totaljoint
Re: Smart Car Seats
Post by totaljoint » Wed Oct 24, 2018 2:48 pm
To be fair, I get more compliments on the smart seats!
Ed
Re: Smart Car Seats
Post by rmel » Wed Feb 13, 2019 6:18 pm
The chap in San Diego is still parting out Smart Car Fortwo's so I picked
up a set of seats for my 712 project.
Plan is to use the lower portion of the Pinz seat frame and weld these
seats in as others have. But...I'm wondering how far down does one strip
down the Seat frames? The PIX's on this thread don't match the seats I
have 100%, there may be variations. From what I can see, I need to take
apart the ball-bearing sliders, retain the top portion of the slider only
and re-bolt that back onto the Seat. If I don't the seat has no solid base,
but that just looks different than the PIX's on the tread so I thought I'd ask.
Rescue Pinz: 73' 712M
Bruce Berger
Re: Smart Car Seats
Post by Bruce Berger » Wed Feb 13, 2019 10:10 pm
Ill be interested to see how you mount your seats. I still haven’t mounted mine. Too many projects and not enough time.
Sent from my iPad using Tapatalk Pro
Bruce Berger
'72 Pinzgauer 710M 2.6i
Re: Smart Car Seats
Post by 4x4Pinz » Thu Feb 14, 2019 5:28 am
personally I mount mine with the frame only. never understand the idea of keeping the sliders and sitting a couple inches higher. with seat backs that actually lean forward and as small as the cab is in a pinz there really is no need to slide seat forward and back. I want the seat pan of the "donor" seat sitting as close to the pinz floor as possible. no complaints to date and have done a dozen or so modifications for folks.
Re: Smart Car Seats
Post by TechMOGogy » Thu Feb 14, 2019 7:58 am
Post a picture of your seats and that may us visualize it
Re: Smart Car Seats
Post by rmel » Thu Feb 14, 2019 9:29 am
I’ll post some pix’s later today. Been constantly raining up here in
The Santa Cruz mountains and power finally called it quits. So will
Be a bit before I get back into this. But ya. I’m tossing the rails
I will need to retain a portion to bolt the two seat members together
This is the part that seems different that what others have encountered.
Sonarman
Re: Smart Car Seats
Post by Sonarman » Thu Feb 14, 2019 11:05 am
I just tried to post pics of my Smart seat install. Keep getting HTTp error.
Re: Smart Car Seats
Post by rmel » Thu Feb 14, 2019 1:12 pm
Ya, I had trouble just posting text this morning, after submit I was taken to page
which then barfed up a fair amount of HTML error messages, although the posting
went through anyway.
Re: Smart Car Seats
Post by rmel » Thu Feb 14, 2019 3:08 pm
These rails are not easy to take apart, PIX below. I got my trusty angle grinder out
and lopped of one end of the bottom slider and that was enough to get the ball bearings
and other bits to come out freeing the slide to separate. I could not figure out what was
holding these in place. It should become a bit more evident why I need the top part of
the slider in the next PIX. The slider bolts together the bottom seat and hing for the backrest.
Now apart, the top portion of the slider is below. Two M6 Torx screws, one front and
one back attach the seat bottom. Two M8 Torx screws in the back attach to the seat
back hing. Without this member the seat parts would not be joined at the hing.
Yes the Pinz frame is upside down and I have not ground off the back frame yet, but it's
in position to show that this should work using the top portion of the slider. There is a
piece of steel looks like a handle in the center of that rail, that needs to be cut that is
interfering that was part of the rail interlock mechanism -- kiss that good by.
Although I think this is perhaps 1/2" higher than would be the case W/O this
member, there's lots more places to weld to. Torn between Torch brazing versus MIG,
my MIG is a POS though :(( gotta figure out how to heat shield the fabric.
Re: Smart Car Seats
Post by 4x4Pinz » Thu Feb 14, 2019 7:00 pm
for heat shield I am fortunate enough to still have some lead sheet. I use it a lot to keep sparks and heat away from things I don't want to get too hot. It is very moldable and real easy to form into any shape I need. even make it fit between material and supports when needed. works better then my fire blankets.
Derrickbwg
Re: Smart Car Seats
Post by Derrickbwg » Thu Feb 14, 2019 7:29 pm
great pics...helps a lot!
Sent from my SM-G935V using Tapatalk
1975 710K
2018 G63
