Small gauge size in dashboard
Posted: Tue Aug 13, 2019 12:41 am
by Jake2015
Iā€™m looking to add a gauge to an open position on my dash. When I remove the plastic cover and measure the hole it seems to be 60mm, or just over 2 1/3ā€. I see gauges with bezels of 2 1/4ā€ but nothing larger until you get to over 3ā€. Has anyone installed into the smaller holes and what size gauge did you use?
Re: Small gauge size in dashboard
Posted: Tue Aug 13, 2019 2:48 am
by Hotzenplotz
Jake
The Pinz is metric. The hole in the dash is exactly 60 mm in diameter and in previous years this was the standard size for several gauges.
Some folks have installed Voltmeters to display the status of the onboard electricals, others have added a second fuel tank and use this hole for the corresponding gauge.
VDO nowadays offers most of these devices in 50 mm diameter, and you can purchase an adapter ring for 60 mm holes with them.
hope that helps
Posted: Wed Aug 14, 2019 9:12 am
by rmel
I've posted this before but easy to get lost in obscurity.
VDO reducing ring: 2 3/8" to 2 1/16" PN# 600-851
https://www.summitracing.com/search?Sor ... ord=600851
