Winch Question
Posted: Mon Feb 10, 2020 3:27 pm
by Tomaboyd
I have an opportunity to acquire a new Warn 80907 (Severe Duty 18K, 24v) winch for small fraction of the MSRP. Less than I would have to pay for most of their other 9-15K winches.
I have a 710M with a nice winch mount.
My question is, is this just a ridiculous winch for the 710. I do intend to replace the cable/fairlead with rope/hawser to save on the weight. I know people have them on 712’s.
Normally I would not consider this winch for my 710, but the cost makes it worth heavy consideration. But I don’t want is to have some big, oversized monstrosity on my front bumper making me look like I am compensating for something.
Thoughts are greatly appreciated.
Re: Winch Question
Posted: Mon Feb 10, 2020 4:49 pm
by rmel
I put a Ramsey Profile 9500 24V on my 710. I also eliminated the controller
and located a heavy duty Contactor in the side of the passengers footwell
to keep the grill more open for air flow. It's a pretty small footprint up
front and the weight is about 80 lbs with a synthetic rope.
What your looking at is considerably heavier and I would assume the
planetary gear housing is pretty large. But, Warn is cheating a wee bit.
That winch only has a 4.5hp motor geared low to 315:1. That's how they
get the pull. To contrast, the Ramsey is a 5.5hp 138:1. So that Warn
may not be as large as one would think for a 18,000 lb pull. It's going
to be very slow though.
So maybe the things to consider are: Weight, potential Blockage up front,
spooling speed versus the bargain it may be.
I'm about to spring for a 2'nd winch for my 712 and might just get another
Ramsey Profile 9500 or perhaps the next size up.
Re: Winch Question
Posted: Mon Feb 10, 2020 5:48 pm
by Tomaboyd
You make a solid point about the dimensions. The Warn M18 is a beast. Significantly larger than the Ramsey Profile 9500. But I an actually get it cheaper than the Ramsey by a fair bit.
Price is not everything though.
Re: Winch Question
Posted: Mon Feb 10, 2020 6:07 pm
by VinceAtReal4x4s
I'd make it look as pretty as possible in pics and post it on various platforms and see if you can make enough to buy a better winch. 18K is just too big. It would be easy to screw up your front-end structure if that thing gets near stall in a heavy pull, etc.. plus the weight and size issues mentioned; that's a lot more weight for a Pinz frame to deal with. My M8000 set-up was under 70lbs on my last rig and that's the winch I recommend to everyone or go up to the 9000-9500 or a Husky 10 for the 712's. You are also looking at much more expensive syn rope having to go to 1/2" and more issues with snatch blocks (depending on model) and so on.
