front seat
Posted: Wed Feb 10, 2021 8:41 am
by Derrickbwg
Its 19" wide
Ive just tacked it in to try on stock lower frame using some rail adapters. head to roll bar bumper height is same as stock, but the side is quite a bit higher. IRemoving the tabs from seat and welding straight tube-to-tube (seat frame to lower tube frame) would help in lowering that height. Its not bad at all for me but i'm only 170lbs so its hardly noticeable. If you slide the seat all the way to the rear it helps clearing the side on entry. It does not fold or recline but its so light it comes out with ease and clears the steering wheel easily. I dont think it will fit well in my k with the heater due to the reclined angle of seat back.
Re: My front seat quest
Posted: Wed Feb 10, 2021 8:47 am
by Derrickbwg
some more
